It is currently Mon May 25, 2026 8:06 pm
PostPosted: Wed Feb 24, 2010 12:33 am
Fresh 360 (4.030 x 3.50) methanol injected chevy engine. Bowtie block. AFR CNC ported aluminum offset heads, Hilborn 2 3/16 inside nozzle injectors with 5 inch nozzles. Eagle light rotating assembly with J &E pistons set at 14:1. Shaver/Wesmar gear drive with KSE cover and water pump. Barnes three stage dry sump. Crower roller assembly with special AFR offset stud girdle. Rockers are 1.6 intake and 1.5 exhaust. Vertex mag with recharged magnets and serviced by Don Zig. Comes with new Hilborn “0” pump, all lines, filters, and jet cans, spare set of SRP 4.040 pistons and a few other parts. Engine has new rings, bearing, rod bolts and of course valve job. No races since fresh.
It made 684 hp on the dyno—then the bearings were checked and it was reassembled.
PostPosted: Wed Feb 24, 2010 12:36 am
Also go this in the trade.
2009 Universal (Brand) Trailer. This trailer has 2017 miles on it. ( San Diego to Pensacola). Super light weight. 8.5 ft wide x 21 ft long x 7 ft tall inside. Brakes work exceptionally well. Diamond plate rubber decking glued on with new process---will no peel up at edges. Inside is beautifully finished with white PVC paneling and epoxy paint. This trailer has not been used—it is new.The price also includes a $1000.00 heavy duty custom cover.
PostPosted: Wed Feb 24, 2010 1:30 am
Shiny... 8)
PostPosted: Wed Feb 24, 2010 6:28 am
:smt023
PostPosted: Wed Feb 24, 2010 7:41 am
nice
PostPosted: Wed Feb 24, 2010 8:58 am
That looks like a nice and healthy motor... like some older sprint car stuff.
Should be a bitchen motor for a LUV after some poppet and barrel valve adjustments. toss in an old Isky "Dial-a-jet" and you could street that hilborn system.
A.j.
PostPosted: Wed Feb 24, 2010 9:10 am
8) Thats very cool.
2006 GMC Sierra 2500 HD
PostPosted: Wed Feb 24, 2010 10:16 am
That's a nice trailer. It's very much like mine. (http://sporttrailersonline.com/Sport_Lite_Photos.html) (this is not my actual trailer, Just the brand) I like that it is already framed for windows.
PostPosted: Wed Feb 24, 2010 5:47 pm
A.j.
I was thinking the same thing...World of Outlaw stuff
PostPosted: Wed Feb 24, 2010 9:43 pm
That is a current 360 Sprint Car engine, that is what mine started out as. The World of Outlaws run a 410 with alum. blocks, that and that damn garage door on their roofs.
PostPosted: Wed Feb 24, 2010 10:34 pm
HAHA...
PostPosted: Thu Feb 25, 2010 9:39 am
so whats the plans for the motor? we gonna LUV it or......?
A.j.
PostPosted: Thu Feb 25, 2010 1:41 pm
Gonna Luv it but changing out the fuel system to a tune port. I already have the setup and the painless wiring harness
PostPosted: Thu Feb 25, 2010 9:25 pm
Make sure the crank will accept a flex plate. Some sprint engines were machined so a plate wont bolt up.
PostPosted: Sat Feb 27, 2010 12:36 pm
Nice! :twisted:
75-luv mikado-V8 350 soon
PostPosted: Mon Mar 01, 2010 9:27 am
so ya wanna seell that mechanical system?
A.j.
PostPosted: Mon Mar 01, 2010 2:50 pm
thats a whole lot of of motor but very nice! :D
1975 luv daily driver.
Project-soon to be revived
PostPosted: Tue Mar 02, 2010 10:46 am
Think I am selling the whole motor. I want something that is streetable and this won't do it. A friend thinks he has a buyer for $8500.00
