It is currently Fri Jun 19, 2026 9:37 am
 Post subject: My 1975 Stepside
PostPosted: Thu Sep 18, 2014 9:34 am
I thought I would make a thread on my new 1975 Stepside.
This is what it looks like now when I bought it. All you not Texan or a southern person please excuse my writing. I speak Texasaneese. As a rural Texan may. College and working in Houston did not break it.
Image Image
 Post subject: Re: My 1975 Stepside
PostPosted: Thu Sep 18, 2014 9:37 am
PostPosted: Thu Sep 18, 2014 9:39 am
Image Image
PostPosted: Thu Sep 18, 2014 10:00 am
It has a stock engine, with Weber Carb, header.
Not sure what and how to do some of it.
Fix fuel pump
Fix the fuel hose to the tank, filer.
Some of the above just needs to be done to make things better.
Fix turn signal switch
add interior door latch little chrome trim
The above were supplied by 2 Luvtruck.com members. Thanks guys
I do not know if they want their names posted or not?
Fix interior.
Install the A/C that was on it previously.
Install the heater.
add Power Steering
add tilt column
Fix any body work.
Paint? Even if it is flat black it needs to be done correctly.
Engine, Transmission, keep or stock? It will have to remain stock for a while. Need to save up some $$$
PostPosted: Thu Sep 18, 2014 10:29 am
Your truck looks a lot like my old 76 did back in the 80's. Right down to the International Harvester tail lights. Mine was yellow though, and wound up in Yakima Wa. with a V8 in it. 8)
PostPosted: Thu Sep 18, 2014 6:31 pm
Nice truck to start with. I have that same grill hanging up in my shop, still not sure if I want to install it on my truck, it looks good on your truck.
PostPosted: Thu Sep 25, 2014 2:16 pm
I do like the dual Luv headlights, but my old 79 4x4 had signal head lights, which I like too.
PostPosted: Thu Sep 25, 2014 5:03 pm
Dibs on the one you got now...
PostPosted: Thu Sep 25, 2014 8:42 pm
Parts whore.
