It is currently Tue May 26, 2026 6:49 am
 Post subject: Recovered Dash
PostPosted: Sun Jul 19, 2009 9:48 am
This would have been MUCH easier and turn out better had the windshield been removed. There are a few spots I don't like, but for now I think it's great. Got a few crinkles (don't do wrinkles) on each end at the doors and A tear in the middle by the radio. I am looking for my heat gun to stretch the fabric and push it down around the instrument console hole. When I recover it long after I rebuild my '53 Ford F100, I will re-foam the entire dash as you can see slight bumps where the new foam meets up with the original dash parts and I learned quite a bit for my first time.
More pics of the LUV on photobucket.com under effie_1953@yahoo.com
Rick
Loranger, La
1980 Stepside LUV (Again)
 Post subject: Re: Recovered Dash
PostPosted: Sun Jul 19, 2009 9:51 am
Looks real nice in the pics. Holy smokes you should see the one in my '79, cracked to hell and curled up like a bowl. That would be a major upgrade for mine.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Sun Jul 19, 2009 9:52 am
looking good
PostPosted: Sun Jul 19, 2009 3:43 pm
Looks real nice.
PostPosted: Tue Jul 21, 2009 10:08 am
It still needs to be cleaned of the contact cement, but here it is. The aluminum rings on the dash cluster are my defroster vents. The cluster can be removed by removing two screws from inside the radio spot. Well guess I need to put the steering wheel in and go to my VA appointment. Will post the grill when I get back.
Rick
Loranger, La
Users browsing this forum: No registered users and 81 guests
