It is currently Tue May 14, 2024 10:32 pm
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2
PostPosted: Tue May 05, 2009 9:11 pm
PostPosted: Tue May 05, 2009 9:12 pm
PostPosted: Tue May 05, 2009 9:13 pm
PostPosted: Tue May 05, 2009 9:14 pm
PostPosted: Mon May 11, 2009 4:57 am
Sooo, whats going on here?
The streets of Tulsa were NOT made for minis >.<*
PostPosted: Mon May 11, 2009 8:01 pm
what do you mean whats going on what dose it look like i pulled the cab so i could fix the floor pans
PostPosted: Mon May 25, 2009 7:25 pm
got some more work done but dont have any pics yet but i will. im going to z the front but im not shure of the best way to do it. should i just cut the frame at the fire wall then notch the core support or cut and section the frame witch would be the easiest.
PostPosted: Thu May 28, 2009 11:47 pm
i hope you are not finished with the rear suspension. the way the upper link bars mount to the frame wont work too well. those little pieces of square tube will tear off. it would be wise to plate the frame with 1/4 inch plate before those pieces of tube are there to stay. and then put a gusset under them, or run a piece of tube all the way accross the frame..i did my toyota similar to what you did and the square tube ripped right off. it actualy tore a hole in the frame.
PostPosted: Thu May 28, 2009 11:51 pm
mine is Z'd like 4 inches in front of the firewall. it is Z'd 1.5 inches. and i didnt cut the front of the frame. on the core support i took out a 1.5 inch section 1 inch above where itmounts to the frame. there is a piece that runs under the radiator that i cut out first
PostPosted: Sat May 30, 2009 3:36 pm
the back is not done yet as a matter of fact the back is getting re done im just going to back half the truck
