It is currently Sat Jun 20, 2026 6:26 am
Post new topic Reply to topic  [ 454 posts ]  Go to page Previous  1 ... 13, 14, 15, 16, 17, 18, 19 ... 23  Next
PostPosted: Fri Jul 25, 2014 8:25 am
frige wrote:
Dont try to fix the old block. I did that once and spent way to much money on it only to replace the block later with a dart block after I ripped the head studs out.
Good advise . It is going to scrap yard today . Probably build a 410 or 412 later as money permits .
PostPosted: Fri Jul 25, 2014 10:09 am
hotrod80 wrote:
It could be sleeved with a heavy wall , but im not going to keep it .
And TP that block and piston didnt have a chance in hell against that Carrillo rod and lunati crank . Rod looks like new crank was still great . Head can be saved . ill repair it as time and money allow . Took 2 years to put this pile together .
I know about that, and am still working on my project. I will get there barring anything anything unforeseen.
PostPosted: Fri Jul 25, 2014 12:13 pm
Thanks , old motor looked good on teardown . Pistons and cylinder walls looked good . Rings and bearings getting replaced . Also upgraded to a beehive spring and retainer . These are surposed to last longer and are lighter at the retainer end to lighten up the valvetrain . Should have the old motor back tuesday . We will see .
PostPosted: Fri Jul 25, 2014 2:45 pm
Looking forward to coming out and watching you race.
PostPosted: Wed Jul 30, 2014 10:14 pm
Well , out with the new in with the old . Kinda glad to have this one back in .
PostPosted: Thu Jul 31, 2014 4:43 am
That was quick. Good to see you almost up and running.
PostPosted: Thu Jul 31, 2014 9:31 pm
Well the big headers leak like crazy on the small motor heads , but it is back together and i drove it enough today to clear out the driver side pipe that was pumped full of oil when it broke . Going to Sealy for the friday jackpot and pinevalley for the ironman challege saturday.
PostPosted: Thu Jul 31, 2014 11:13 pm
Cool. I may see you at Sealy tomorrow night.
PostPosted: Fri Aug 01, 2014 12:39 am
i wonder if that radiator gets hot... :lol:
PostPosted: Fri Aug 01, 2014 4:57 am
Upside down it reads TOH TOH.
PostPosted: Fri Aug 01, 2014 5:07 am
It wont take long to figure it out . I have had 2 people touch it . Probably not a problem when the hood is on , but my wife put her hand down on it and my neighbor did also .
PostPosted: Fri Aug 01, 2014 5:14 am
Ouch!
PostPosted: Fri Aug 01, 2014 10:10 am
ouch 8O
my remote oil filter bracket has HOT extruded on the surface of it and I still managed to put my hand on it when I was looking at my carb... ouch.... luckily my palm didn't say toh on it afterward :lol:
glad to see you got your other engine rebuilt with the newer parts so quickly at least you wont be down and out for long
PostPosted: Fri Aug 01, 2014 12:03 pm
The truck looks awesome as always. Good luck at the track! 8)
PostPosted: Fri Aug 01, 2014 12:08 pm
You race at Pine Valley? I have a good friend that races there...Bryan Hoffman.. He sponsors the Metco 5.80 index race. Not sure if he does the bracket races though.
PostPosted: Sat Aug 02, 2014 7:36 am
Well had a pretty good night . New motor did really well minus the exhaust leaks . Got 4 test passes in and ended up breaking out in the final . but made a bit of money . Had a great time . Pine valley today for the Iron Man classic . Luvstruck came out also . Good to see you again .
PostPosted: Sat Aug 02, 2014 12:29 pm
Well as they say at the bank, "there ain't no flies on that". First time I have seen the truck, and what an excellent job you've done with it. That was some excellent racing, and how that other guy got you was luck. He was coming on strong on the big end and just hit the brakes and hit his exact number. Couldn't believe it. Good luck today in Lufkin.
PostPosted: Sun Aug 24, 2014 6:24 am
Had a good night . Worked hard for this .
PostPosted: Sun Aug 24, 2014 6:28 am
Wow, now thats cool. Always wanted a wally.
PostPosted: Sun Aug 24, 2014 7:55 am
NICE!
