It is currently Thu May 07, 2026 12:41 pm
Post new topic Reply to topic  [ 54 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: 1972 Mikado Reborn
PostPosted: Sun Jan 05, 2014 5:12 pm
Yes the reg says 73" I had the truck in storage for a year just got it out.Never really looked at the reg. or title because I have so many other cars.
PostPosted: Sun Jan 05, 2014 5:14 pm
Not even a space.Clean..
 Post subject: Re: 1973 Luv Reborn
PostPosted: Sun Jan 05, 2014 5:16 pm
I looked all over that cowl and it has no spot for a tag.
PostPosted: Sun Jan 05, 2014 5:22 pm
the last guy I got it from had cut almost all of the firewall it out. why,I have no idea.there was no floors,or tranny tunnel in it.There is no rust on the truck,which I first thought was the reason the floors were gone.I have no Idea why the last guy did what he did?? :?
PostPosted: Mon Jan 06, 2014 1:05 am
Sounds like a body drop was in the works...
PostPosted: Mon Jan 06, 2014 9:47 am
I was thinking the same.
PostPosted: Mon Jan 06, 2014 10:44 am
The VIN number is stamped on the cowl somewhere, if not it was ground down.
PostPosted: Mon Jan 06, 2014 1:58 pm
I checked inside and out.no tag or space for one.No mark if there ever was one.No grinding marks to be seen?
PostPosted: Mon Jan 06, 2014 3:32 pm
I just went out an checked mine, it is right here.
closeup crappy camera pic
PostPosted: Mon Jan 06, 2014 7:16 pm
Ill check again.Thanks..
PostPosted: Mon Jan 06, 2014 7:36 pm
Found it under old paint.C58281253
PostPosted: Mon Jan 06, 2014 8:32 pm
If you look at the picture I posted earlier that is not a LUV vin number. On some early models I found them to be on the opposite side. Not sure what other owners have but all 3 of last LUV's matched the numbers on the cowl to the VIN.
PostPosted: Tue Jan 07, 2014 9:56 am
Ill go over the other side and check.
PostPosted: Tue Jan 07, 2014 8:30 pm
After talking to a few other LUV owners I stand corrected. The first Vin you posted was CLN1488281253, like the book says that is a 78 model year. Then you posted it was really CLN1428207021, that is a 73 model year. Then you posted the cab number is C58281253, as far as we can tell on the cab numbers the last 7 is supposed to match the last 7 of the frame and other VIN numbers. So the cab numbers match the first VIN you posted and some how you own a 78 LUV. someone swapped cabs for VIN numbers. All of the other owners I talked to say their cabs start with the c5 then followed the rest of their VINS.
PostPosted: Tue Jan 07, 2014 11:35 pm
I went through the engine compartment and found the cowl was welded back together for what reason I cant say.The DMV here in Ca, has it registered as a 73' so,I'll leave well enough alone.I just went to the DMV today and my reg matches in their system as well. I've already have a ton of work,money and time in this.I bought a 39' Ford coupe so I'm going to sell the this Luv and also pick up another one I found on sat.This time I will check it out thoroughly! Supposedly it is a 74' we'll see. Thanks very much for trying to decode this mystery truck for me. Paul.
PostPosted: Wed Jan 08, 2014 6:56 pm
Where is the frame number at?
Mike & Chanin Saiki
http://www.motivational.net
PostPosted: Wed Jan 08, 2014 7:05 pm
Usually in front of the fuel tank stamped in.
PostPosted: Wed Jan 08, 2014 9:34 pm
You a big Judas Priest fan?
PostPosted: Wed Jan 08, 2014 9:58 pm
Yes.Why?
PostPosted: Thu Jan 09, 2014 12:42 am
The song "Breaking the Law" keeps running through my mind...
