It is currently Sat May 23, 2026 9:24 pm
Post new topic Reply to topic  [ 80 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Wed Apr 14, 2010 8:46 am
so i will be postin more info on the build soon i am really sick right now just starting to feel a little better i got to pull the motor out and put it in the shop.....prob will rebuild it back to stock my dad says he dont like boring motors out and junk lol....
Chevy luv with a redneck grabber green paint job lol...
these are links to my luvs pics.
http://s922.photobucket.com/albums/ad68 ... v%20truck/
viewtopic.php?f=33&t=22598
:usa :minigun: :bio:
PostPosted: Thu Apr 15, 2010 7:33 pm
Stock 1.8L is around 85 horse power. There is alot of info out here in building engines if you use the search button. There is a sticky out here that has alot of info in it. It's called, "Fullaluv's Birth of an engine" and is on the stock truck homepage. I wasn't a member when that individual posted the thread and...well it was an interesting article to say the least. If you read it you will see what I mean. Anyway, it's a decent article and has some good info. There is alot more info out here as well. Ask if you get into any trouble.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Sat Apr 17, 2010 9:47 pm
alright awsome i will prob end up rebuilding the motor back to stock all original or w/e is cheap.....
PostPosted: Sun Apr 18, 2010 12:19 am
I just rebuilt my Isuzu. Cost about 900. Got the kit from Parts train (450) and found that
1. The throw out bearing is pressed onto the clutch fork. Had to take it to a machine shop.
2. The piston ring thingy (Forgot the name) but holds the piston head to the shaft, was also pressed on.
After putting the engine back in I changed from the Hitachi carburetor to a Weber, HUGE difference.
Good luck. Make sure you post pics. :D
PostPosted: Sun Apr 18, 2010 12:40 am
Undefeated in Trivia
You talkin' about the pin that holds the piston to the rod? If so, that's a wrist pin.
1980 Shortbed Mikado 4x4
1977 Chevy K20, a little more than mild 350, sm465, np205, 2.5" suspension lift, 37" tires
1995 Ford F150, 300 I-6, ZF-5, bw1356, 6" suspension lift, 3" body lift, 36" tires
PostPosted: Sun Apr 18, 2010 11:29 am
awsome veemanator thanks for ur info i will start pullin the motor soon just got over being really sick now trying to get stuff straighten out with my gf car.
also did u take ur motor and ur head to the machine shop?
PostPosted: Sun Apr 18, 2010 9:07 pm
Yep, took the head to the shop (135.00 ish) and I honed the cylinders. And, yes in my last post I was talking about the wrist pins.
PostPosted: Wed Apr 21, 2010 12:02 pm
chrisquested wrote:
Wow this sucks so bad my trucks motor is knocking bad and smoking white smoke like crazy!!! lmfao this sucks well i was excited/happy for a good 20 mins on the way home from the auto part store then i get home hook everything up and then i hear it knockin and smokin....so this limited budget just turned into a new project! ima pull the motor and rebuild it......so any info you guys got on rebuilding it plz leme know now!
On our 1977 LUV Mikado, the timing chain chewed into a water passage that is molded as part of the aluminum timing chain cover. The dealer we had the truck into in 1982 replaced the head (which had tested as good), head gasket and rings BUT did not fix this issue, thus $1,400 later we still had a water-in-the-oil problem (lots knocking, lurching, lots of white smoke!) until WE found the problem ourselves because we were too broke to let these "experts" continue.
I do not know what year your truck is, but if your timing chain was rattling at all, pull the timing chain cover and check if the integral water passage has been breached by the chain. It may not actually need a full rebuild, just a flush-out and a timing chain cover replacement (tighten the chain, too).
We've been doing most of our own work on our truck ever since, a dealer shop manual for the 77 LUV is worth its weight in gold. (We asked for and retained the parts that were swapped out, most of these are probably fine.)
Good Luck!
KP
If necessity is the mother of invention, then I am the bastard love-child of invention and desperation.
-KP
PostPosted: Wed Apr 28, 2010 12:00 pm
awsome right now i am trying to get my girl friends saturn fixed her timing chain broke and bent 13 out of 16 valves.......so i got the head redone and bought all the new parts geting it fixed now....
PostPosted: Sun Jul 25, 2010 7:45 pm
Ok guys!!!! i got my gf car fixed it has been for about 3 months and now the baby is here and everything is good so guess what! the luv truck is back in progress......ok so now i dont know if yall know but the luv didnt run when i started it it was knocking so i got the motor pulled and it will be put in the shop tomorow only prob is were do i get an over haul kit from.....!?plz help me with that i figured ebay but idk if i can trust ebay..alrighty well i am happy to be workin on this thing again finaly. :lol: 8) :o :D
PostPosted: Tue Jul 27, 2010 5:18 pm
CONGRATS on the baby!!
NAPA can get a rebuild kit. For the heck of it I looked on JC Whitney a while back and they have a complete rebuild kit as well. I've never used a kit from Whitneys but I guess it is an option. I think most parts stores can get what you need, it might take a little time but they can get them. Keep us posted.
1981 Luv 2WD
1981 Luv parts trk
PostPosted: Wed Jul 28, 2010 10:02 am
ok awsome i should be geting my motor out of the shop in a day or two. right now i am fixing wires that got chewed on by the dang rats lol, then i will start sanding the cab so i can primer it for now.
PostPosted: Wed Jul 28, 2010 4:09 pm
so like i said the motor is in the shop....when i pulled the head off 2 valves was stuck wide open......then found out that the rear main seel was leaking...and i got to figure out somthing for when i get my motor back i need to get a fuel pump but everytime i search for one its always an intank filter but this truck has it mounted to the frame? wtf?
PostPosted: Wed Jul 28, 2010 10:01 pm
It's amazing you are building an '80 4x4 Luv the same time my son is. His is on a budget as well and we just painted it Monday night. We shot it with Van Sickle paint that he bought from FLEET supply where he works. He's now putting the interior back together and getting ready to spray on a bed liner from Orielly's line of that product. I haven't found a original replacement fuel pump but there are some out there that will work. Good luck with your engine.
1981 Luv 2WD
1981 Luv parts trk
PostPosted: Sat Jul 31, 2010 11:01 am
wow thats awsome dude i just got my engine out of the shop....one piston was messed up the head was warped and 2 burnt valves total cost = $290....so i got to find a piston for my truck but no auto part store can get it wtf.....i will get pictures up soon.....
PostPosted: Mon Aug 16, 2010 10:54 am
selling this luv truck shoot me some offers !!!!
PostPosted: Mon Aug 16, 2010 3:00 pm
Selling it!?! That's to bad.
1981 Luv 2WD
1981 Luv parts trk
PostPosted: Fri Aug 20, 2010 4:07 pm
wow i am starting to tinker on my truck again because i have only had 1 guy come look at it.
Any ways wtf has this guy done to his intake or w/e that looks like horns lol????
PostPosted: Sat Aug 21, 2010 2:20 pm
Ok guys here it is soon to come new pics of the progress!!!! i had the truck listed and only had one guy come out to check it out...So i went out side and was looking at the truck and i ended up messing around with it again!! so the pics will be up on the site very soon.
PostPosted: Sat Aug 21, 2010 3:16 pm
i would like to put a bed/roll bar on my luv and make it look some what like this guy did his toyota.
