It is currently Mon Mar 02, 2026 6:24 pm
 Post subject: gauge cluster
PostPosted: Fri Feb 21, 2025 4:20 pm
hello , just bought a 1976 luv two wheel drive automatic , it has a two gauge dash cluster. the question is can i put a three gauge dash cluster in place of the two gauge . thanks
 Post subject: Re: gauge cluster
PostPosted: Tue Feb 25, 2025 9:06 am
Yes. The wiring will probably need to be adapted and you might need the vent/plastic pieces on both sides. Google LUV gauge cluster and you'll see the two different clusters.
PostPosted: Tue Mar 04, 2025 8:58 am
THANKS FOR THE REPLY WILL CHECK IT OUT.
PostPosted: Wed Oct 01, 2025 12:02 pm
hello, on a 2 gauge cluster there's a C -light on the left side next to it on the right side there's an O is that for oil light or overheating
light thanks
light thanks
PostPosted: Wed Oct 01, 2025 5:27 pm
I'm guessing here, but I would say C is for charge (alternator) and O is definitely for oil pressure.
PostPosted: Thu Oct 02, 2025 10:34 am
ok thanks
