It is currently Tue Apr 16, 2024 10:25 am
Post new topic Reply to topic  [ 81 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: 1972 luv project
PostPosted: Mon Jan 14, 2019 6:16 pm
I , starting to try and find out all the parts I nedd and where to get them for my Truck. I know it has a 350 Chevy motor, a turbo 350 trans, a ford nine inch rear end, and front disk brakes of a 1976 Chevy luv truck. Driven it a little bit, then put a set of points and condenser in the distributor. I will be changing the distributor later for a MSD small cap model, and a MSD box.
I went to my local parts stores. Neither the Auto Zone, Discount, or Orielys carry a rebuilt caliper to replace the frozen one on the drivers side. I did see a codine unit at summit that seems to be about two weeks off to get here. I will post some pictures when I get the resizing thing figured out.
PostPosted: Tue Jan 15, 2019 9:24 am
You can find a good amount of parts on ebay. On the brake caliper, I took my old ones to a NAPA store and had them send them to their rebuild center. It was Cardone that did the work and I found them on line and through ebay also. And they were cheaper than NAPA. So do a little research and you can find them cheaper.
PostPosted: Wed Jan 16, 2019 9:01 pm
carburetor on the motor
File comment: carb on top
PostPosted: Wed Jan 16, 2019 9:04 pm
The passenger side of the engine compartment
File comment: drivers side engine compartment
PostPosted: Wed Jan 16, 2019 9:06 pm
Drivers side of the engine compartment
File comment: drivers side of the engine copartment
PostPosted: Wed Jan 16, 2019 9:10 pm
Somebody has made some of the dash parts in wood. this is a shot of the clove box and center councel they made.
File comment: Glove box
PostPosted: Wed Jan 16, 2019 9:14 pm
For now it has the old points distributor, I have replace the points with a new set of accel points. this is a shot before replacing the distributor.
File comment: distributor
PostPosted: Wed Jan 16, 2019 9:18 pm
The breaks that are on it, at this time, are from a 1976 Luv according to the numbers on the parts.
File comment: Caliper
PostPosted: Thu Jan 17, 2019 10:15 pm
Right now its a twenty footer. It looks great from twenty feet away lol
File comment: passengers side
PostPosted: Thu Jan 17, 2019 10:16 pm
the drivers side..
PostPosted: Sat Jan 19, 2019 8:09 pm
Fabbing a caliper and mount from a 1982 Trooper to fit on the drivers side. I just noticed I posted my pictures on the classified page. lol
PostPosted: Sun Jan 20, 2019 10:37 pm
Nice looking LUV. Like the color. I put the Ford 8.8 with posi in mine with custom axles drilled for Chevy 5 lug and redrilled the front for the same. I have a '72, came with front discs that were swapped no telling when. I just did the install 10 months ago so everything is new.
PostPosted: Mon Jan 21, 2019 9:43 pm
The caliper started like this.
File comment: start
PostPosted: Mon Jan 21, 2019 9:44 pm
I cut this part off..
File comment: cut line
PostPosted: Mon Jan 28, 2019 9:05 pm
if you take this clip of the brake line and loosen up the nut, you can then twixt the break line where it needs to be to mount the 1982 Iuzu caliper.
File comment: clip for breaks
PostPosted: Mon Jan 28, 2019 9:07 pm
The clip hold this down so it won't move.
File comment: break line
PostPosted: Mon Jan 28, 2019 9:10 pm
After some paint and loading the caliper with the pads, it will fit on the front of you Chevy Luv truck.
File comment: fitts
PostPosted: Mon Jan 28, 2019 9:13 pm
It centers well on the rotor. The brake fitting is however in a different location then the old one.
File comment: fitting shot
PostPosted: Mon Jan 28, 2019 9:18 pm
You need to use the bolt from the old caliper, as the one that comes with the 1982 Isuzu one is longer, and has a smaller hole then the one for the Chevy luv.
File comment: banjo bolt
PostPosted: Tue Feb 12, 2019 9:37 pm
I went to work on the passenger side breaks, and noticed the mud control flap on the inner fender was melted. I am guessing it gets a little hot down there.
