It is currently Tue May 26, 2026 10:38 am
Post new topic Reply to topic  [ 213 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11
 Post subject: Re: Norms 75 luv build
PostPosted: Sun Feb 10, 2013 10:47 am
drummerforhire the offset of the wheel makes it clear the inside frame . you mite have more room to the out side with the stepside , id do some measureing between the flleetside and stepside from frame to the lip on the bed .
PostPosted: Sun Feb 10, 2013 1:40 pm
The stepside box hangs over the frame a little. I might be able to fit 255s if the offset is perfect.
How did you find those wheels with the 5.25 offset? I've looked all over summit and I only see the 15x8s with a 4.25 offset.
PostPosted: Sun Feb 10, 2013 8:16 pm
we called Summit racing and had them made . they well make just about any width and offset that you need . the tire is half the eqaution . we picked these tires because they had all the right numbers [ rollout , width and the side wall flex ] . we found that the width of the rim is real important to how the tire flexs side to side . we just got back from the car show had alot of fun .
PostPosted: Sun Feb 10, 2013 8:59 pm
Man, that is fantastic information. Thank you so much! I didn't know they'd make them custom like that. I know exactly what to do now. Thank you again.
PostPosted: Thu Mar 07, 2013 6:53 pm
Congratulations on a super job on you LUV! Very clean and nice work. It came out looking great!
PostPosted: Thu Mar 07, 2013 9:36 pm
thanks shellfish . the build was as fun as it gets . im dreaming up my next project . lets say luv frame , 46 jeep body , 455 olds motor and not sure if it well be 4x4 or not ? but old school use what i got build.
PostPosted: Fri May 09, 2014 9:34 pm
PostPosted: Thu Jun 19, 2014 10:23 pm
Are those factory LUV discs? If not what brand are they? If original factory discs, how well do they stop with the added weight of the v-6? and I'm curious about weight difference between factory LUV and your custom truck. Factory weight being just over 24xx pounds what was the final weight after customizing?
Let me xray you, you will feel better.
PostPosted: Thu Jul 03, 2014 9:12 pm
they are stock discs and they stop the truck fine . the master and peportioning block and all lines are not stock . as for the weight ? ill have to weight it .
PostPosted: Thu Jul 03, 2014 11:10 pm
My truck like many here with small blocks have no problem stopping with the stock front brakes.
PostPosted: Tue Aug 05, 2014 12:02 am
I really enjoyed this build up. Your LUV turned out fantastic!
PostPosted: Thu Jun 11, 2015 9:57 pm
got a new luv project in the works . 78 extended cab short bed . when its done that is .
PostPosted: Fri Jun 12, 2015 11:45 pm
Good luck on your new project.
