File comment: One coat of bed liner.
After the first coat this is what I ended up with. I was feeling pretty excited at this point.
File comment: Close up of first coat.
I was pretty happy with the texture of the first coat. I figure all the whining I've heard over the years about excess spray buildup was probably from people who did not read the instructions. Shake the can for two minutes before use and only apply on low humidity days between approx 70 degrees farenheit to some higher number than my climate gets ever. I left my sunroof open for ventilation but closed all my windows and the door I was not standing in. That brought the temp from about 65 outside to a perfect eighty degrees or so for curing.
File comment: Everything replaced.
Everything back! There will be more posts as this summer progresses, I'm sure.
Thanks for reading!
