It is currently Thu Jun 11, 2026 10:47 am
Post new topic Reply to topic  [ 213 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11  Next
 Post subject: Re: Norms 75 luv build
PostPosted: Sun Jan 01, 2012 8:09 pm
got the wiring loom done . The front end , headlights ect. ect . all done and the loom to the back lights , done . and still cant see wirers under the hood .
PostPosted: Sun Jan 01, 2012 11:17 pm
Very nice work! As mentioned, great to see a truck done ground up and treated like more than a $500.00 beater!
PostPosted: Mon Jan 02, 2012 6:23 am
Using push lock fittings for the heater hoses i like it .
PostPosted: Mon Jan 02, 2012 9:21 am
Looks like a custom centerlink in your suspension, where did that come from and why did you go that route?Any other front suspension upgrades or changes?
PostPosted: Mon Jan 02, 2012 10:04 am
the whole front suspention and steering is stock 75 luv stuff with a 90 tropper box . the center link is just painted
the rear i droped 2 in. and took out the overload spring to get a 2.5 drop
other than that i figured why mess with a good handleing truck , just softened it up alittle in the back .
PostPosted: Mon Jan 02, 2012 10:13 am
i cant remember where i got the idea
but i think it had something to do with these . plus they look cool
PostPosted: Wed Jan 04, 2012 10:36 am
rad is fitted and heading to the welder to get tabs welded on
PostPosted: Sun Jan 08, 2012 9:22 pm
well got the radiator mounts made
PostPosted: Sun Jan 08, 2012 10:36 pm
first fit of the dash . fits preety good
PostPosted: Sun Jan 22, 2012 10:51 pm
well a littel more done on the luv . carb on distributor in oil primed and dipsticks shortened .
oh yes the moter is all wired and ready to go . but you cant find the wires .
PostPosted: Sun Jan 22, 2012 10:53 pm
did a littel work on the sound deading today
PostPosted: Sun Jan 22, 2012 10:56 pm
Coming together nicely...
PostPosted: Sun Jan 22, 2012 10:58 pm
thanks mytmouz
PostPosted: Mon Jan 23, 2012 8:48 am
I take it when you put a carb on the motor there is no need for the ECU. Nice I have a 4.3 in my Astro van that I was going to take to the junk yard but I may keep the motor/trans for a future project.
I have worked in a hot rod shop for 3 years and this looks like hi caliber work nice job.
Kelbone
I want to be a minitrucker when I grow up
PostPosted: Fri Jan 27, 2012 10:53 pm
did somthing a littel diffren t to the rad . powder coated the tanks only .
PostPosted: Fri Jan 27, 2012 11:03 pm
man that truck is coming along great! im working on a 4.3 to drop in my luv..
how big is that radiator? im gona need one for mine... mine just wont come out looking that good :lol:
PostPosted: Sat Jan 28, 2012 6:42 pm
The truck is coming along nicely and thanks for the pictures!
It's looking great!
PostPosted: Sat Jan 28, 2012 8:53 pm
Nice attention to detail 8)
PostPosted: Sat Feb 11, 2012 7:10 pm
power steering pump brackets and hoses in and done .
. rad is in and allmost done just need to run tranny lines
. heater defrost ducts in , i used shop vac hose ends and they fit perfectly
. tommrow well put the dash in for good and then the sterring column . the luv well go to the muffler shop wed. .
PostPosted: Sat Feb 18, 2012 6:28 pm
well its in for good
