It is currently Tue May 26, 2026 1:08 pm
PostPosted: Sat Feb 20, 2010 10:02 am
My dad gave this truck to me with a broken timing chain. And so the rebuild begins.
Im new at this Pic. thing hope this works :?
File comment: The motor after my brother worked on it.
PostPosted: Sat Feb 20, 2010 2:17 pm
Takind a break so Im posting more pic. of the build.
File comment: The chain
File comment: engine with bad chain
File comment: Doner engine had a rod knocking
PostPosted: Sat Feb 20, 2010 4:58 pm
Here are some more Pic. of the build
File comment: The motor in the truck and runing. My best time ever,the motor started in lest than a min. after the first trun of the key
File comment: The new motor
PostPosted: Sat Feb 20, 2010 6:15 pm
Wow! You work on a different schedule than me. Was this all in one day?
Glad to see it's back running.
Eric Q.
My build thread.
PostPosted: Sat Feb 20, 2010 9:07 pm
We have seen far worse come back to life here. Looks good so far.
PostPosted: Sun Feb 28, 2010 11:24 pm
No it took me 3 weekends it's just that I took time to upload some of the Pic. of the rebuild. :)
And so here are some more Pic. of the work done in the last 3 weeks.
File comment: rewiring the tail lights (now were having fun)
File comment: better
File comment: needs a little work
PostPosted: Sun Feb 28, 2010 11:25 pm
PostPosted: Mon Mar 01, 2010 2:52 pm
coming along nicely!!! keep up the good work. wish I could get that much done on my 1975.
1975 luv daily driver.
Project-soon to be revived
PostPosted: Tue Mar 02, 2010 9:55 pm
I completed going over the rearend 2 weeks ago here are some Pic.
File comment: Here I bushed the axle out of the bearing and bearing holder with a 2 nuts, and bolts
PostPosted: Tue Mar 02, 2010 10:07 pm
OOPS I hit the wrong key. Here is the rest of the Pic. of how I removed the axle, and the tool I made to work on the rear axle.
File comment: Her is the tool for removing the axle nut.
File comment: There were 2 holes in the Backing plate, and Bearing holder that I used 2 1/2" bolts, and nuts to push the axle out. By the way these holds were threaded so you could use a MM bolt.
PostPosted: Wed Mar 03, 2010 10:22 pm
Some more pic. on the rear axle redo as its going together :D
PostPosted: Sun Mar 14, 2010 10:08 pm
Up date the frond end is finely done after 3 weeks of getting parts. Here are some more Pic. of the work.
PostPosted: Sun Mar 14, 2010 10:14 pm
And some more
