It is currently Tue Jun 09, 2026 2:39 am
Post new topic Reply to topic  [ 94 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: kaotikl luv
PostPosted: Thu Mar 04, 2010 10:29 pm
What do you mean around the doors?
PostPosted: Mon Mar 08, 2010 8:09 am
on a few of the bd trucks ive been looking at where they cut the floor by the rockers they had to sheet it in to fill the gat so their was like astep on the inside behind the rocker....if that makes any sense to you i might be able to find a pic to show u what i mean
Epic Fabrication.
KAOS
PostPosted: Tue Mar 09, 2010 8:45 pm
started the body drop tonight hope to have the floor braced up either 2morro or the next day and have it home to test fit the placemet of the motor..
Epic Fabrication.
KAOS
PostPosted: Wed Mar 10, 2010 1:08 am
Your doing a traditional body drop, best way to plate by the doors is at a slated angle, easier to work with. I didn't have to do any of that, I have a stock floor body drop, my cab has a new frame underneath, I just sectioned my cab mounts to match the new frame, everything is in stock location besides the trans tunnel because I had to lift it 3 1/4"(same distance as the body drop)
PostPosted: Wed Mar 10, 2010 7:38 am
kool yehai hope to have it done by next monday at the latest..
Epic Fabrication.
KAOS
PostPosted: Wed Mar 10, 2010 5:15 pm
ok got the body drop done turned out to be lil over 4 1/2 inches so now im sittin at if i rem right 3ft 8 in from ground to roof
Epic Fabrication.
KAOS
PostPosted: Thu Mar 11, 2010 10:00 pm
Very nice any pictures?
2006 GMC Sierra 2500 HD
PostPosted: Sat Mar 13, 2010 3:53 pm
yeah i have some up soon as my laptop gets back from gettin fixed ill catch every one up on the build shouldnt be more than a couple of days
Epic Fabrication.
KAOS
PostPosted: Sat Mar 13, 2010 5:13 pm
I didn't touch your laptop. I swear! I only broke mine! :lol:
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Tue Mar 16, 2010 7:29 am
ok this sux i cant put up pix ill try and get one up of it layd out but the progress will have to wait..for any ones records that will be baggin or might be baggin the tranny xmember hangs bout 1/2" lower than the frame..but i gotta take mine out so i can slide the motor back and imma redo the xmem with 2x2 steel tubing with 4link bushins on the ends so its removable..after that ill be sittin at a smoothe 3ft 71/2"
Epic Fabrication.
KAOS
PostPosted: Fri Apr 02, 2010 4:18 pm
heres a small updat well i got my laptop fixed so i can start back up loading pix have some up monday of whats been done so far
Epic Fabrication.
KAOS
PostPosted: Sat Apr 24, 2010 1:20 am
little late on the update :mrgreen Your build looks good
PostPosted: Tue May 25, 2010 3:34 pm
heres some updtes on my build
theres some of the start of the body drop
Epic Fabrication.
KAOS
PostPosted: Tue May 25, 2010 3:50 pm
heres some more angles of the body drop..
dont kn if u can read the take but its jus over 4 1/2"
heres some of wher i fit the motor in come to find out my motro and tranny are bout a inch and ahalf 2 low and the truck is laying out on both the oil pans...gota fina a way to make some lift plates to weld on top ofthe motor mounts and bolt the adapters to
Epic Fabrication.
KAOS
PostPosted: Wed May 26, 2010 6:48 am
Bagged79 wrote:
kaotikl is right, if you have drop spindles you don't have to Z the frame. If he kept stock 6 lug he would have had to Z because they don't make spindles for luvs, checked into when I body dropped mine
curious to know if i have stock s10 spindles and im not going to run a 20" wheel .. will i have to Z the frame to lay out?
... ill be running DHP arms.
PostPosted: Wed May 26, 2010 7:32 pm
yo0u only need drop spindley for any thing over 18"s they keep the geoometry closer to stock on bigger wheels..but even with 18 id invest in some spindles is what they are mainly for but with the c arms from mike you should be ok with stock spindles..if u dont run bigger than like 17s is what i would say
Epic Fabrication.
KAOS
PostPosted: Tue Jun 15, 2010 10:18 pm
hey guys kno its been takin a while for me to update its js cuz its hard for me to get on lately but trucks comin along pretty good not where i want it to be but havin to wait on money is a big issue right now finished up the bodydrop and finishin up the bd on the bed now..hope to have it al primed up and the rood on by summer show down..but still have a long way to go on the body work still gota strighten everything up and get everything braces for good but after the bed is bded ill [ost some new pix of the build so far....
Epic Fabrication.
KAOS
PostPosted: Tue Jun 22, 2010 9:33 am
i know its the little stuff ... but i really really like how you cleaned up the frame rails by welding up the edges. looks sooo much better
PostPosted: Mon Aug 02, 2010 1:16 pm
thanx for that..well not a lot has been done to it lately threw it together for summer showdown and o therthan that aint touched it much lately..but im finn cut it back upand ditch the whole rear clip and everything from the middle of the cab back and build a whole new piece outa 2x3 and rebuild it to lay out on some bigger wheels..ill try and post the pix from drop jaw some time soon thier on the web site under perry ga july 3,4 like in the 125 page or so
Epic Fabrication.
KAOS
PostPosted: Wed Oct 06, 2010 4:32 pm
so whats the news on this bad boy? wanting to see some more progres
