It is currently Fri Jun 26, 2026 4:11 am
 Post subject: 2 inch lift
PostPosted: Thu Feb 09, 2006 3:00 pm
My 2 inch lift made my luv look a lot better, that and I went a little bigger on tires. =-P
PostPosted: Thu Feb 09, 2006 4:36 pm
Banishment Pending
yup a little lift does have that effect :twisted: :twisted:
PostPosted: Thu Feb 09, 2006 8:01 pm
how did you lift your truck? I have 2 80 Luvs and would like to lift both of them.
 Post subject: other post
PostPosted: Thu Feb 09, 2006 11:05 pm
Opps, looks like I created a new post instead of responding to the Poll on body lifts.
I bought the body lift kit off a company that posts in JCwhitney. I would suggest the 2 inch lift, as 3 inches requires brackets that must be welded.
The only mods that gave me some greif: I had to cut a hole above the where the stock steering column goes, and one of my brakelines I had to replace as it was not long enough to get to one of the front brakes. Though I'm wondering if this is the case because mines a 4x4. I just used a floor jack and some blocks of wood to first raise the bed one side at time, then do the cab.
PostPosted: Fri Feb 10, 2006 12:48 am
Banishment Pending
Accually No they don't, at least on my 80 only one set had to be welded, the other I bolted in, I just drilled some 1/2" holes in them so that they would bolt to the frame.
PostPosted: Tue Feb 05, 2008 10:54 pm
Those of you that have a 2 inch body lift, what's the largest size tire you can put on there? Meaning at what size will work with the fenders, before you have to modify them. 8)
