Hello all
recently acquired a 79' Luv 4x4. wanting to fix it up to take into the mountains and go fishing/hiking/camping/4Wheeling (light)
the luv is mechanically sound and everything works. quite a bit of body rust. frame is in good shape, as is the engine.
the camper will be taken off. and might be used at a later date.
so I'm starting my build with the suspension. since the engine works. What I would like is about 2" from cranking the T-bars. Then maybe another 2" from a body lift. so, here are my questions.... 1) I would really like pictures (if anyone has) of using the Trooper upper control arm that helps resolving suspension travel from cranking the T-bars. 2) where can I get the body lift?
anythings helps . looking forward to becoming a part of the LUV community
lots of work to be done
