It is currently Fri May 03, 2024 7:48 am
 Post subject: Luv 4x4 conversion kit
PostPosted: Sun Oct 16, 2016 8:52 pm
Years ago I took apart a 4x4 luv, at the time I thought it was a Wolverine? conversion.
It used a dana front axle with the factory brake calipers, rotors are 6 lug.
transfer case looks like a jeep/dana with an adapter on the front to make it remote mount
I will try to get a couple pictures on here in the next day or 2
PostPosted: Mon Oct 17, 2016 8:49 am
sweet deal i haven't seen one yet
PostPosted: Wed Oct 19, 2016 7:54 am
Now you have.
PostPosted: Wed Oct 19, 2016 7:12 pm
So is it a jeep style transfer case?
PostPosted: Wed Oct 19, 2016 8:43 pm
If your question is directed to me my t-case is a divorced Dana 20. At one time or the other D20s were used in about every brand 4x4 vehicle in production, including several models of Jeeps over the years. In that sense it is a Jeep style transfer case.
PostPosted: Tue Mar 13, 2018 11:54 pm
There were quite a few companies doing the 4WD conversions initially. Downey Toyota was a big one on the left coast. . Almost all used the Dana 44 front end on jeep springs, offset hangers welded to frame, with the Dana 20 transfer case in a custom made, bolt up carrier. They had a short maybe 6" long drive shaft from transmission to transfer case.
PostPosted: Wed Mar 14, 2018 10:10 am
I never saw a Downey conversion that used a D44, all I saw used a D30, the reason being the D30 was readily available in the correct width. Any stock vehicle of the day that used a D44 front was way wider & a conversion would have required a cost prohibitive custom width axle housing. Plus if the vehicles being converted used a stock rear axle the D30 was comparable in strength, the D44 was overkill, especially considering the stock engine horsepower. The Downey D30 version was pretty much a stock IH Scout/Jeep CJ unit & used the 5x5 bolt pattern. Since these were 2wd trucks that used a smaller 5-bolt wheel pattern an adapter to convert the rear to 5x5 pattern was included in the kit. The other companies that offered conversions for Chevy LUVs, Ford Couriers & Datsun pickups fitted fit 6-lug hubs to the D30 axle that matched the stock 6-lug rear pattern.
The narrowest D44 of that era that I know of is the narrow track Jeep Wagoneer at 61", a LUV is 54" WMS to WMS. For a comparison a typical full size pickup is 65".
The first gen IH Scout fronts were about the right width, but they were also D30s. When the Scouts went to the D44 front the vehicle got bigger & the axle wider.
PostPosted: Mon Jun 08, 2020 10:17 am
Here is a Baja 4-Wheel Drive conversion brochure and a few old 4x4 conversion magazine ads.
PostPosted: Thu Jun 11, 2020 8:14 am
I found this Chevy LUV 4x4 conversion on the Petersen Archive in the 1978 SCORE Mexicali 300 race.
Link: https://archive.petersen.org/pages/sear ... &offset=0#
Baja Four Wheel Drive Conversions Chevy LUV 4x4-1.jpg [ 188.52 KiB | Viewed 9030 times ]
Baja Four Wheel Drive Conversions Chevy LUV 4x4-2.jpg [ 241.02 KiB | Viewed 9030 times ]
