It is currently Thu Mar 28, 2024 2:34 am
PostPosted: Fri Oct 07, 2016 7:53 pm
I've got my hubs off my luv to replace some wheel studs. I'm going to replace the wheel bearings and grease seals.
I got the new grease seals in the mail, but they look a difference design. The diameter looks like it will work. However the new seal has a inner and outer lip to it. The smaller circumfrence lip has to go downward. but by being place into the hub the cup part (or open part) of the seal faces the opposite way. I'm not sure if it will hold the grease in. See pictures attached. Old grease fitting is on the Left side.
PostPosted: Mon Dec 12, 2016 12:22 am
Turned out Rock Auto didn't ship the right seal. I took one of the old seals to a local auto supply, and new and old ones matched there.
PostPosted: Mon Dec 12, 2016 9:34 am
I found 6 different front cv axles that matched my 79 4x4. None fit. Put NOS Chevy LUV parts in ebay. Lots of seals and goodies show up.
