It is currently Tue May 05, 2026 6:32 am
 Post subject: frame question
PostPosted: Sun Sep 20, 2015 9:14 pm
I have a 1980 4x4 LUV that I want to SAS with coilovers. my plan is to buy a 2wd frame and build my 3 link setup on it and then swap running gear and body to it ( so I can keep driving my LUV until it is a ll ready). so basically i'm just wanting to make sure that any 1972-1980 frame will work. I'm pretty sure the frames are all the same for the first gens but I just want to make sure. Any help would be appreciated
1980 4x4 LUV, 3 inch body lift, 4.56 gears, 31x12.50r15 Super Swamper IROKs, Weber Carb, Electronic distributor,
 Post subject: Re: frame question
PostPosted: Sun Sep 20, 2015 9:54 pm
There are some small differences in the frames. The one that I had was the bumper mounting is different.
PostPosted: Sun Sep 20, 2015 10:48 pm
Motor mounts on yrs 72-75 are different than 76-80.
PostPosted: Mon Sep 21, 2015 7:56 pm
Basically what I need to know is if my body will bolt on to another frame so it sounds like it should! Thank you guys! Guess ill have to get newer than 75, glad I know that haha
PostPosted: Mon Sep 21, 2015 8:42 pm
All of the gen 1 bodies will bolt directly to a 72-80 frame.
PostPosted: Tue Sep 22, 2015 9:04 am
Awesome. thank you!
Users browsing this forum: Bing [Bot] and 5 guests
