It is currently Tue May 05, 2026 11:50 am
PostPosted: Tue Mar 24, 2015 7:28 am
just got new brakes rotors and pads for the front of my 79 luv from orielly's. for some reason the pads will not fit on the rotor when installed in the caliper. has anyone had this is issue? if so what is the solution?
PostPosted: Tue Mar 24, 2015 10:59 am
Did you use a c clamp to push the brake piston back when you were removing the old ones? If you don't push it back the new rotor will be too thick to fit.
Did you buy standard luv rotors?
PostPosted: Wed Mar 25, 2015 5:20 am
yes i pushed back the caliper and did buy standard rotors same as the old one that where on there. i didnt know if there was some trick to getting the pads to fit
PostPosted: Wed Mar 25, 2015 6:56 am
If they're close to fitting, you can take your rotors back to oreilleys and get them turned and that'll take a little off. It's not a bad idea anyway. I've bought new rotors before that were a little off.
PostPosted: Wed Mar 25, 2015 2:05 pm
or - just spitballing here - take the pads to the disk sander for a sec and remove a bit of the cheaper material instead.
