miike wrote:
Ok I got it. Had to mess with it for a bit make sure it's all lined up. I think when I turned with pliers it may have bent out a little flange that keeps the spring from popping apart but I was able to bend it back straight with channel locks. Whole job turns nice and easy on both sides now. I highly recommend the ebay brake rotors. These things are silent and should last for a very long time.
u probably got the same ones i did
around $60 little less... I think they were a basic trooper caliper a shop took and drilled/slotted, I spent a bit of time looking at the machining on them and part of the engraved edge saying thicknesses was machined off when they slotted them
Luvless
