It is currently Fri Mar 20, 2026 2:57 pm
 Post subject: Royal Purple Synchromax?
PostPosted: Mon Jul 15, 2013 8:55 pm
Hello All
I am still pretty new to these forums, been reading but not posting. I have a a 1980 mikado 4x4, and I am curious what lubricant to use in the manual transmission/transfer case? I have used Royal Purple Synchromax before in my bmw's, which required ATF in the 5 speeds... just curious if anyone has tried this Royal Purple stuff before? I have read on here that a lot of people seem to recommend a good 30w motor oil in the tranny/transfer case. Which 30w is recommended? I would like to use a synthetic if possible... had really good luck in the past.
Here is a link to the Synchromax stuff. http://royalpurpleconsumer.com/products ... ion-fluid/
Any help is appreciated! And thank you!
PostPosted: Mon Jul 15, 2013 9:05 pm
Motor oil is what is supposed to be in it. Pick any type you would want. Most have no issue with the regular type.
PostPosted: Sat Aug 03, 2013 1:23 pm
What weight of oil do people recommend using? My Haynes(yes crappy) manual says to use just engine oil. So 10w30 is good enough? Or just just straight 30w a better choice? I am getting ready to drive this pickup to Burning Man in a few weeks, which is held in the Northern Nevada Black Rock Desert. Figure temps of 100 degrees, but I do plan to do most of my driving during the cooler mornings.
Is Power Punch a good idea, or bad idea? My transmission seems to shift alright, some minor noise in first gear when I left off the gas but this is not bad... not nearly as much noise as an old chevy or Ford truck 4spd tranny. I have never been one to use Power Punch, but if a little bit will help then I will use it.
PostPosted: Sat Aug 03, 2013 2:57 pm
Use whatever viscosity is appropriate for the motor, based on the expected temperatures while driving.
