It is currently Mon Jun 29, 2026 7:25 pm
PostPosted: Tue Feb 28, 2012 12:49 pm
hellow my names john and i have a 79 chevy luv 4x4 and the stock 1.8l is about shot has a rod knocking and am thinkig hard on either sbc or 4.3l my main concern is the trans and transfercase will the original 4sp bolt up to a sbc? or will the original transfercase bolt up to a th350? im on a budget so i cant sped a lot just a little toy for now or does any no wat other motors will bolt up to the original trany? i woul love as much feed back as possible thanks!
PostPosted: Tue Feb 28, 2012 6:08 pm
There are several half completed threads on here, and a couple of completed ones. Basically, you will have to replace the tranny and transfer case. Most are trying to do an SAS front end swap, using a toyota front diff...
PostPosted: Tue Feb 28, 2012 9:32 pm
Yup!! I would be one of em!!! I'm working on it though!!
Jim
80 LUV 4X4 Stock Drivetrain, 3" Body Lift, Shackles & Torsion Twist
99 K2500 7.4l 4l80e all stock
PostPosted: Wed Feb 29, 2012 11:38 am
well i have thought a bout getting an s10 trans and transfercase cuz i no the 4.3l bell housing is the same for a sbc but another question are the 79 toyota trucks have same front fenders?
PostPosted: Wed Feb 29, 2012 12:26 pm
You'll have to swap the tranny & t-case if you go with any engine other than another Isuzu 4 cylinder. And the big problem is finding an engine that will clear the front driveline.
Your picture must show '79 frame/running gear (1st year for 4x4) topped by a '77 (last year for quad headlights & wing windows) or older body- correct?
PostPosted: Wed Feb 29, 2012 12:30 pm
im not sure lol this is the first love iv had so i dont no much about them yet the title reads 79 but it may have had other pannels put on it im not sure
PostPosted: Wed Feb 29, 2012 6:06 pm
No...
PostPosted: Fri Mar 02, 2012 2:03 pm
ok iv just seen some and they looked simaler and wasnt for sure well thanks for all the help!
