It is currently Thu Jun 18, 2026 7:15 am
 Post subject: carb for offroad
PostPosted: Thu Dec 15, 2011 9:45 am
im curious to what carb you guys are running for offroad use? the only carb im finding most use on a g180 is the weber but in the samurai world everyone hates the weber the moment you are on a real incline. any help would be greatly appreciated
 Post subject: Re: carb for offroad
PostPosted: Fri Dec 16, 2011 8:05 am
24 views and not one person has any suggestions of a carb to run offroad-hmmm
PostPosted: Fri Dec 16, 2011 12:30 pm
Since you are limited to either the stock Hitachi or the aftermarket Weber there's not a lot to suggest.
PostPosted: Fri Dec 16, 2011 1:29 pm
the weber is a great carb i run one on my luv..
if your going up an extreme incline your going to have fuel delivery problems no matter what carb you have...
if you want to be able to go drive up a wall go with a propane carb system and you could drive upside down if you felt like it. other than that i recommend getting the weber
PostPosted: Fri Dec 16, 2011 2:01 pm
Before ripped my luv apart, I went up and down some pretty step stuff, and the weber i had did great, never had a problem with it dieing, but :lol: if you luv is pretty stock then your not gona really be able to do the kind of "offroading" really needed to cause dieing. :lol: My advice to you would be if your gona do some major "offroading" then buy a Toy or an ranger or somthing. Just my .02 cents anyway. :lol: and the Search bar will help you out a lot. Theres loads of info on here!
