It is currently Thu Jun 18, 2026 7:15 am
PostPosted: Thu Sep 22, 2011 5:16 pm
has anybody ever converted a 2 wheel drive luv to a four wheel drive luv. i have a 77 4x4 with a bent frame and bought a 71 2 wheel drive as a swap frame. i dont no what i might run into anybody with any insight is gratefully appreciated.
PostPosted: Thu Sep 22, 2011 10:16 pm
Australian LUV Guru
77 was not a year for factory fitted 4x4, you most likely have a custom job on a 2wd frame. Chop the front axel out of the 77 and weld back into the 71 (?) along with the engine mounts as 77 & 71 (?) mounts are different.
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Thu Sep 22, 2011 10:17 pm
if I was so do it i would go grab a set of toyota 4x4 axles with solid front axle and the 4x4 transmission from another luv... or better yet from an 86-87 trooper 4x4 or a p'up 4x4 so u can have a 5 speed 4x4..
PostPosted: Thu Sep 22, 2011 11:18 pm
There were no luvs that were a 71 model year
