It is currently Thu Apr 18, 2024 5:03 pm
 Post subject: How to guide?
PostPosted: Wed Jul 06, 2011 10:14 pm
Does anyone have a "How to guide" they can post for any of the following...
btw i Have a 79 luv 4x4
Soa-
t-bar crank-
sas-
body lift-
Pics would also help a TON!!!
Thanks
I have taken it wheelin all ready on street tires and she does pretty good but i need to be able to get over rock's and stumps 8)
 Post subject: Re: How to guide?
PostPosted: Thu Jul 07, 2011 6:06 pm
soa- don't unless you also sas, the front can't be raised enough with the t-bars to level it out. Use a helper spring or longer shackles.
t-bars- take the weight off the front wheels, turn clockwise, 1 turn = 1/4" lift, don't max out, it will be too bouncy.
sas- '79-'85 toyota pickup/4runner straight axle is only 1-1/2" wider than your rear, same bolt pattern, most came with the same 4.10 gears as a LUV, mount it with leaves, it will clear the steering better sua.
body lift- buy a kit, follow the directions that come with it.
PostPosted: Fri Jul 08, 2011 2:48 pm
Thanks Man :D
