It is currently Sun May 05, 2024 10:57 am
PostPosted: Sun Jun 12, 2011 5:47 pm
High guys im new to the website and i gotta say all the info has been helpful. But me and my uncle are restoring a 1978 4x4 Luv. Here's our dilema.... When we got the truck it's previous owners had installed 3 inch body lift blocks under the cab and bed to help clear larger tires. Well when the cab was raised.... sadly the shifter was not. lol so in order for the shifter to be able to move into 2nd, and 4th gear. the floor around the shifter had to be trimed so the shifter could move back far enough. lol well honestly it looks tacky, so id like to take some sheet metal and fill up the hole they cut there. only prob is i dont know what can be done to extend the shifter 3 inches...... any ideas guys? suggestions are welcome. Thanks.
P.S.- also looking for ways to lift the truck thru suspension lift. We dont wanna jack up the torsion bars in the front. So also, Suggestions welcome. Thanks again :D
Danny Boy
PostPosted: Mon Jun 13, 2011 6:52 am
The only front suspension lift is to crank the t-bars.
BTW- 1st year of 4x4 LUV was 1979, unless it's a conversion your truck is not a '78.
PostPosted: Mon Jun 13, 2011 8:05 am
I used this style boot to cover the hole in my floor. And a smaller same style one for the t case shifter.
http://cgi.ebay.com/ebaymotors/Hurst-Su ... 3f0a7e6bb0
PostPosted: Mon Jun 13, 2011 7:33 pm
oldestisuzuist wrote:
The only front suspension lift is to crank the t-bars..
I haven't tired it, but there's a post where you can get the A-arms off a Trooper and flip the ball joints upside down. That would raise the front supesion some.
PostPosted: Mon Jun 13, 2011 8:52 pm
This is my swap and lift using Trooper front control arms and the rear springs witch give me about a 3" lift and a good ride. The spacers are from independent 4X4 and are mounted under instead of through the top. The rear leafs are Trooper bolted to the LUV main leaf.
PostPosted: Tue Jun 21, 2011 8:06 pm
Thanks guys, all the input was greatly appreciated. Thanks for the link btw!!! loads of help, also. My truck is a 79 i feel stupid. lol and now my screen name makes no since!!! lol! But thanks guys! ill keep you posted on the build. Maybe able to up load some pics soon.
Danny Boy
