It is currently Thu Jul 02, 2026 1:11 pm
PostPosted: Sun Oct 03, 2010 7:15 pm
I DID SOME SEARCHING AND COULD NOT FIND THE ANSWER IM LOOKING FOR.
HAS ANYONE DONE A LUV BODY SWAP TO A ZR2 FRAME AND DRIVE TRAIN (4.3 VORTEC TBI). HOW GOOD DOES IT MATCH/FIT.
THE WHEELBASE IS ABOUT 6IN DIFFERENT WILL THIS BE A PROBLEM, WILL THE ENGINE FIT BETWEEN THE WELLS AND UNDER THE HOOD.
THANKS FOR ANY HELP
PostPosted: Sat Oct 30, 2010 11:06 pm
It should fit just fine, however I'd consider just swapping the drivetrain onto the LUV chasis, the frame on the LUV is fully boxed, and if I recall correctly, the ZR2 is C-frame.
PostPosted: Sat Mar 12, 2011 1:17 pm
i have a 98' zr2!!!!! i flipping luv this truck!! it is awesome and near unstoppable. i bought it to replace my luv that I'm trying to swap either the body onto my 84 k-10 or the running gear into the luv frame. probally swap the running gear but if i had an another zr2 i would use it's frame instead and put a luv body on it!
