All one unit, one drain plug, one fill plug. Fill with the correct weight engine oil for the ambient temperature. BTW a good way to fill- get a cheap garden sprayer, remove the wand spray end, fill with the correct amount of lube, pump it up, stick the wand end into the fill hole, lock it on & go do something else until the sprayer empties. Also works on differentials, just slower because of the thicker lube.
_________________ '78 Chevy LUV,1.9,4sp,headers,31's,SAS Dana 30,Dana 20,SOA rear w/Aussie Locker, rough body, bought new 12/4/78. '87 Trooper,2.3,5sp,headers,31's,ball joint flip & spacer,Aussie Locker rear,Superwinch hubs,brush guard w/5.5K winch,more to come.
