Alright so i got the idea for a custom lift while working on a barn, funny i know. But we were welding on some 4 inch tubing and then it hit me. Since there are no lifts made for the LUV except universal ones i thought why not make one out of some 4 inch tubing. I thought that i would run it the length of the cab on both sides and 1 along the front for the fenders. Either do the same on the bed or just short individual pieces for each bolt. Call me a redneck if you will but I'm from Oklahoma so I'm used to it
If you think this is a good idea plz let me know and when i start on it (which might be possibly tomorrow if i can make it to the hardware store) I'll post some pics. I believe it will work out fine but whatever problems I run across I'll let y'all know. And if it works it should work with any size tubing. Oh and I'll also be reinforcing the bolt areas in the cab for the extra support.
