It is currently Tue Jun 30, 2026 2:10 am
PostPosted: Sat Apr 03, 2010 4:05 pm
has anybody thought of putting leaf springs on the front of a LUV for the extra lift? If so what all have you done and what would be the best springs to use? I've thought about doing this but thought i would see if anybody has done this yet. I know if i do this i will have lengthen front drive shaft and steering column and a few other mods but somebody please tell me if you have done this or ever thought about doing this. And also are the U joints the same on a LUV as on a K5 Blazer i know LUVs are not Chevy but just asking...
When in doubt floor it. If you can't floor it then you've doubted yourself.
PostPosted: Mon Apr 05, 2010 12:18 pm
No, U-joints aren't even close. You'd have to get one of them nifty adapter u-joints, or just get a bigger u-joint holder thingy for the shaft.
You are talking about doing a SAS, right?
PostPosted: Mon Apr 05, 2010 1:06 pm
Actually i have a 4x4 system from a '75 K5 and i want to put the axels from the K5 on the LUV but keep the original engine and tranny. I already know how to mount the axels the the frame even though the K5's is 3 inches wider (i'm a good welder and a decent fabricator) I was just wondering what i wouls need to bolt the drive shafts from the LUV to the K5's axels. Where could i find one of those adapters? Thx for the info and once i start I'll post pics. It'll be fun moving the steering system lower to stay even with the axels :ebiggrin but I'll get it done. If you have any better ideas plz let me know. Thx again.
sorry i meant '72 K5
PostPosted: Mon Apr 05, 2010 1:41 pm
Crossover steering would let you not have to lower the steering box, but is also just a better system. Are you planning on doing the outboard leafs as well, or are you planning on running v like springs? I'd like to not have to run outboard, but its the only solution I've come up with....
I know a lot of off-road suspension/driveline specialty shops sell the adapter u-joints, but the full size to luv is a big jump, I'm not sure if they'll have that dramatic of an adapter.
PostPosted: Mon Apr 05, 2010 2:20 pm
Yea I plan on doing outboard unless I can find another solution. And that will suck if I can't find an adapter because I really like the four banger and four speed plus I'm currently rebuilding the engine. If I can't find an adapter for the K5 what would be the next best set of axles?
PostPosted: Mon Apr 05, 2010 7:26 pm
The best axles and springs to use would be the early Toyota 4X4 set up as they are the same width as the LUV and a whole lot lighter then the full size Chevy axles.
PostPosted: Mon Apr 05, 2010 9:09 pm
Yet the strength is lacking. Likewise, a wider track is much more stable whilst off-roading.
Even if you can't find an adapter, I wouldn't change axles, I'd change driveshafts. Custom driveshafts aren't too expensive, and would be a lot stronger than stock anyway.
PostPosted: Mon Apr 05, 2010 11:48 pm
A driveline shop can make you driveshafts to connect the K5 axel to the LUV transfercase.
PostPosted: Tue Apr 06, 2010 7:39 pm
Lacking strength if you using a bad V8 yes but with the stock 75-80 horse motor not a chance of tearing the Toyota axles up.
PostPosted: Wed Apr 07, 2010 11:38 am
40 inch tires don't need a lot of horsepower to tear up little axles.
PostPosted: Wed Apr 21, 2010 11:29 pm
Ditto "luvrv8" Just have shafts made by a driveline shop.
In the early years the LUV 4WD were conversions. They mainly used jeep axles, springs, and cross steer.
