It is currently Thu Jun 20, 2019 5:37 pm
PostPosted: Wed Mar 31, 2010 7:10 pm
this luv costed me 200$! i bought it brought it home it was siting for 8 years..... so i tryed to start it but it wouldnt all it did was crank so we checked for spark and there was nothing so i bought a new coil and still nothing so next day my buddy comes over, he calls his dad and his dad told him to stick a screw driver in between the point set he did that and it fired up....so i changed the oil and now i need to get a fuel pump i am also in the process of sanding the frame down.....anyways more info on it at the site below.....!
cant figure out how to post pics.... so i got them put on this site her is the link!!!!
8)
http://www.cardomain.com/ride/3847109
Chevy luv with a redneck grabber green paint job lol...
these are links to my luvs pics.
http://s922.photobucket.com/albums/ad68 ... v%20truck/
viewtopic.php?f=33&t=22598
:usa :minigun: :bio:
PostPosted: Wed Mar 31, 2010 9:45 pm
Welcome to the foeum and we would like to see pics and good deal on the price where are you located
PostPosted: Wed Mar 31, 2010 9:51 pm
Sounds like a good deal. Welcome to the site.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Wed Mar 31, 2010 10:23 pm
i am located in hondo tx its about 45 miles from san antonio i been looking around on this site and i wanna do a 2-3 inch body lift crank my t bars and put some 29/10.5/14r tsl super swampers will they rub at all i wonder? pics can be seen on cardomain i cant figure out how to post on here.... sry... wish i knew how....
PostPosted: Wed Mar 31, 2010 10:28 pm
I just saw your pics. Nice find. You got some work to do, but it looks do-able.
PostPosted: Thu Apr 01, 2010 10:02 am
:D yea my dad is going to rebuild my carb and i almost got the frame all sanded its gona take me about 2 days before the rear end gas tank frame and bottom of bed are sanded and sprayed then idk about the body lift.....but its w/e i will get it all done 8) btw i like ur ride also man its nice
PostPosted: Mon Apr 05, 2010 2:45 pm
hey my truck sat for 10 years i changed the oil rebuilt carb and put a new coil my dad said its gona spin a bearing because it sat for so long.... wat should i do is this true? idk......
PostPosted: Mon Apr 05, 2010 2:57 pm
I'm not sure on the spinning a bearing but it would be best to go ahead and rebuild the engine anyway since it was sitting for 10 years which means the gaskets are probably shot. I got a full rebuild for about $150 which includes all gaskets, oil pump, bearings, rings, and timing set.
PostPosted: Mon Apr 05, 2010 3:53 pm
well it starts up and runs so idk ima get 5 gallons of gas and let it just sit there idleing for awhile then i will do another oil change then i will try and drive it i guess....... idki might go ahead and rebuild the whole motor
PostPosted: Mon Apr 05, 2010 4:52 pm
ok the tires i wanna put on are 225/85/14r they are tsl radials will they fit with the stock lift? or do i gota crank t bars and do body lift they are like 28-29 inch tall and 9 inch wide??? help me leme know
PostPosted: Mon Apr 05, 2010 9:01 pm
They should fit, if not, trim.
PostPosted: Tue Apr 06, 2010 1:44 pm
i am planing on crankin the t bars and also puting 2 inch body lift so i want the tires to look good and and be to small but my dads truck has some 235/85 i put them next to the truck and they looked like they would fit tight so with the bod lift and t bar crank its gona be sitin good i think
PostPosted: Tue Apr 06, 2010 2:07 pm
Undefeated in Trivia
I think you should just go ahead and sell the truck to me. For a little bit of profit.
1980 Shortbed Mikado 4x4
1977 Chevy K20, a little more than mild 350, sm465, np205, 2.5" suspension lift, 37" tires
1995 Ford F150, 300 I-6, ZF-5, bw1356, 6" suspension lift, 3" body lift, 36" tires
PostPosted: Tue Apr 06, 2010 3:37 pm
lolz i cant sell it it is the only 4x4 i could afford to buy...plus all my buddys wanna buy it if i sell it though i will send u a msg
PostPosted: Wed Apr 07, 2010 5:45 pm
ok i figured it out! i know ho to post pics now!! w00t w00t!! this is my $200 luv truck and i got the gas tank painted with a ruberized bed liner and i will be painting a few things with engine enamel.....
PostPosted: Wed Apr 07, 2010 7:47 pm
I like to put Mystery Marvel Oil in something like that. Just me... It helps lube everything. Quiets hydraulic lifters and such things. I know the Luv doesn't have hydro lifters, but you get the idea.
PostPosted: Wed Apr 07, 2010 8:06 pm
hmm mystery marvel i can prob get it at auto zone right? 8)
PostPosted: Sun Apr 11, 2010 1:42 pm
putting marvel in there could cause a problem since its been sitting for so long. if the gaskets are not bad right now, which they more than likely are you just are not seeing signs yet, they will be bad for sure after marvel. the reason why is because of the detergents marvel has in it and they will break up any residue that has built up around the gaskets which could eventually lead to a leak. so i would go ahead and rebuild the engine which is almost always the best thing to do. just my opinion though.
PostPosted: Sun Apr 11, 2010 3:07 pm
hmm that is true but all the gaskets look good lol the valve cover gasket and the intake exhaust and carb were all really good like new looking no oil or anything on them....the inside of the valve cover was really clean no oil or nothhing caked on it....
