It is currently Tue Apr 16, 2024 5:03 pm
 Post subject: lifting doesn't lift??
PostPosted: Fri Mar 05, 2010 6:55 pm
Hi folks.
Cranked the torsion bars, got the lift up front i wanted, no worries.
Tossed these helper springs on and got zero....not an ounce higher than they were....wrong item??
http://www.amazon.com/Superior-11-1020- ... B00029K022
Thibble. :twisted:
Thibble:
'59 Fairlane
'65 Mustang 289
'72 Suzi GT550
'80 Luv 4x4, weber, electronic iggy, 2" suspension lift
'93 Metro convertible
'93 Metro convertible (evil twin)
'03 SLK 320
'06 H2
PostPosted: Fri Mar 05, 2010 7:47 pm
Might have to put longer shackles on with several holes in it until you get the ride height you want then cut off the rest.
PostPosted: Fri Mar 05, 2010 9:13 pm
go to junk yard and get a set of coil springs off the front of a older
car put them between the frame and rear end. you can make the
mounts with large muffler clamps. cut the top bump stop to fit
inside of the coil. dont put LONG shackles on, it makes the LUV
look like it came from south of the border
geo
PostPosted: Sat Mar 06, 2010 2:26 am
You need a add a leaf, not a overload spring-
Chevy LUV Add A Leaf Kit - 1- 2 LIFT
#RS60612
Year Range: 1972 - 1982
Make/Model: Chevy LUV
Brand: Rancho
Chassis: 4 WHEEL DRIVE
Description: Each Rancho Add A Leaf Kit we stock for your Chevy LUV features high quality standards. All our components for guaranteed performance and quality.
#RS60612
Brand: Rancho
Chassis: 2 WHEEL DRIVE
PostPosted: Sat Mar 06, 2010 8:16 pm
Ah very good..
Thibble:
'59 Fairlane
'65 Mustang 289
'72 Suzi GT550
'03 SLK 320
'06 H2
PostPosted: Sat Mar 06, 2010 11:48 pm
Autozone should have a long generic helper spring set in stock for about $40. Mount it on top of your short overload, under the rest of the springpack. You will need longer center bolts, maybe u-bolts if you don't currently have about 1/2" thread sticking through the nuts.
