It is currently Sun Jun 28, 2026 11:58 am
PostPosted: Sat Jan 31, 2009 1:49 am
just bought a built 327 7000 (execellent condition) miles for
$300, looking to put in luv, what type of tranny (manual) and transferr case can someone suggest? Totally aware that I'll be upgrading axles and rearends. Looking for anyone who can help with ideas on how to make this work. Building for rockcrawling.
Thanks :?
[b]Sandy Orr - Keeping the world Green and Growing
PostPosted: Sun Feb 15, 2009 12:46 pm
I know you looking for a manual, im going with a t-350 with a mild 327, im using the stock dana 20 transfercase, axles in it are a dana 44 up front and the stock rearend out back(dont know what it is). For a 4spd i would go with a muncie or if you can find something, and if you could id go with the dana 20 as well, my last luv had the np-203 in it. im not an expert but thats just my opinion.
'79 4x4 Luv, swapped 327, T-350,Project
PostPosted: Sun Mar 01, 2009 12:39 am
You might consider a TH350C trans wired to a switch. I have mandrel bent production fender well headers for that conversion. Can post pics if interested. See www.photobucket.com/v8luv Build several years ago with the dana axle and divorced transfer case. If you can find a copy of Four Wheeler magazine Nov 77, you will see a toyota that I built. More power and better mileage than the 4cylinder.
PostPosted: Wed Nov 25, 2009 4:37 pm
Old Rob PM sent.
PostPosted: Mon Dec 14, 2009 1:13 pm
i would look at the sm420. has a great granny and is bomb proff. will mate to a gm 205. also indestructable but not that great of low. advanced adapters can get you a adapter to go to a dana 300. then you get great gearing and a strong case. but for the rocks i dont think a automatic can be beat. if you are already done with this swap let me know how it went and what you think. i see this is a old topic.
do everything in you life so you can put your name on it
