It is currently Wed Apr 24, 2024 12:15 pm
 Post subject: webber ?
PostPosted: Sat Oct 10, 2009 8:38 pm
i am new to the whole performance part of this and was wondering what kind of weber i need for my 80 4x4. gas milage isnt a big deal as long as i get 12-15 mpg. ive seen some webers on ebay for a lot less the the standard 300+ $. what is the whole dgv-dgev-dgav etc...
 Post subject: Re: webber ?
PostPosted: Mon Oct 12, 2009 12:02 pm
the whole "dgav ev, dfav dgv ect. is telling you weather its a automatic choke, electric choke, or manual choke.
the carb you are going to want to get with the stock 1.8 liter is the 32/36 dgav or ev. http://www.webercarbsdirect.com/category_s/432.htm that is where you will find the carbs you need. i get pretty good gas mileage and a little more power from putting that carb on.
PostPosted: Mon Oct 12, 2009 7:45 pm
:x well crap! i just won a dfev on ebay for bout $90 including shipping today. will it work or did i just get screwed?
PostPosted: Mon Oct 12, 2009 8:07 pm
DG*V, the star tells you electric or hot water choke, DGV, manual choke.
DF*V, the same, DFV, manual choke.
Difference between DFV and DGV is that they are a mirror image of one another. Typically a DGV carb is used on these trucks. I think the gas, throttle and choke may be in non-standard positions, but I think you could still hook it up.
If you go to the site main page there is a .zip file with datasheets on all the Webers. Just look it over and you'll see the difference.
PostPosted: Mon Oct 12, 2009 11:29 pm
I tried to hook up a mirror image carb,a holley weber copy,it turned out to be more of a pain in the a** than it was worth.there is a description of how it can be done,i think it is in the stock g 180 performance tip section of drivetrain upgrades,good luck.
76 mikado project,mean green
PostPosted: Wed Oct 14, 2009 5:14 pm
alrigt thanx a lot 4 the info. i hope i can make it work. B.T.W. Do u guys kno te proper internals it shud have for these trucks(wat size jets). it the stock 1.8 r the main and 2ndary jets the only things to change out or is there more to check out.
