It is currently Sun Jun 28, 2026 8:33 pm
 Post subject: 88 trooper question
PostPosted: Fri Oct 09, 2009 8:45 pm
are 88 trooper 4x4 parts interchangeable? with an 80 luv?
 Post subject: Re: 88 trooper question
PostPosted: Sat Oct 10, 2009 1:39 am
Australian LUV Guru
Im not sure bout 88 but i have used parts from 84/85 Troopers.
Engine, trans , diffs , steering box, brakes, are interchangeable.
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Sat Oct 10, 2009 10:43 am
'88 & newer Troopers had different motor, trans, clutch setup, front & rear differentials, rear brakes, & 4" wider track. '88 & newer pickup & Trooper everything pretty much same. Early '87 & older Troopers had the same front & rear differentials (but 4.56 gear ratio) as an '80 LUV, trans swaps ('86 & '87 are 5spd's), same cable clutch system, '86 & '87 motors will swap but require engine compartment mods, '84 & '85 direct fit, Trooper track is 4" wider.
Easiest Trooper (any year) swap items into an '80 LUV would be the upper control arms (more travel and/or lift) & the bigger front calipers & rotors.
PostPosted: Sat Oct 10, 2009 8:24 pm
Just to add the upper control arms on the 87 late and up will not fit the LUV's ,the power steer box's will fit but you need to use the early 87 and older pitman arm.The early Trooper rotors and calipers fit and the rotors are way lighter vented ones.
The 2.3 & 2.6 engines will bolt up to the LUV trans.
PostPosted: Mon Oct 12, 2009 11:57 am
ok thats kinda what i was thinking. just wanted to make sure. thanks.
PostPosted: Mon Dec 28, 2009 2:17 pm
hey guys. im getting ready to go pick up a 86 trooper. its a parts vehicle, but i just wanted to make sure that the year of the vehicle will work for power steering and maybe tranny? i just wanted to get some more info on what parts are interchangeable with my 80 luv.
PostPosted: Tue Dec 29, 2009 10:36 pm
i was wondering on the same lines. i have a 85 (any ideas on 2.3 power?) 5spd i beleave. i wanted to swap diffs, tranny, and control arms on. dont mean to hijack.
do everything in you life so you can put your name on it
PostPosted: Fri Jan 01, 2010 6:06 pm
I have Trooper upper control arms,5 spd trans and power steering on my truck.
The parts came off an 87 late model so the Upper arms didn't fit so went to a wrecking yard and got early ones and a early pitman arm to fit the steering box.
If you look under my post you will find some write ups on the swap and some pic's.
PostPosted: Sat Jan 02, 2010 9:05 pm
84/85 troopers are a 1.9L 85~HP and all have a 4 speed,
gas door in frunt of rear passenger tire tank is mid ship mounted and only holds 10~ gallens
all 84/85 models are long two door.
the 86/87 ones have the 2.3L 110~HP rare 2.2L T\D 85HP and all have a 5 speed.
all troopers 86 and newer
have a rear tank thats 20+ gallens filler behind passenger side tire.
86 is the first 4 door year, 88 is the last long two door year.
89 is the rare short 2 door year.
all 84/86 troopers have the same axils as 4X4 luv/pups JUST THERE 4.55 GEARS NOT 4.11s
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
PostPosted: Sun Jan 03, 2010 8:25 am
very helpful. thanks much. dodged a bullet :D
PostPosted: Sun Jan 03, 2010 2:20 pm
If you have a chance to get an 86 trooper "GRAB" it as almost everything on it will fit you 80 4X4.
PostPosted: Mon Jan 04, 2010 12:54 pm
well the guy screwed me over on the 86 trooper. it has no title so i have no way of getting it to a junk yard for they will not take it without a title for when i am done with it.
so now i think the project im going to try to do is take a toyota chassis and put my luv body on it. i know theres
a sections on here where a guy did the same thing with pics and steps for how to do it. the only problem is it doesnt come with a motor or tranny/tranfer case. and i dont want to run the stock 1.8 with the 4spd. but the guy im getting the chassis
from is a friend of mine and should sell it for a good price so i might still have money left for a motor and tranny :) i heard that the 22ret is a pretty good motor but the stock turbo isnt that good and they only get a top of 150 hp. but i hear the toyota tacoma motor is a good motor to swap if it has a turbo. anybody have any ideas on what i should do?
