It is currently Mon Jun 29, 2026 12:10 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
 Post subject: CV AXLE
PostPosted: Mon Nov 30, 2009 5:44 pm
Do I need to drop the entire front end to change out the Passenger cv shaft? Thanks in advance
 Post subject: Re: CV AXLE
PostPosted: Mon Nov 30, 2009 8:45 pm
Ok finally found my answer in an old post, for those of you who are curious the answer is yes. CRAP. Sounds like a good time for a SAS
PostPosted: Mon Nov 30, 2009 11:20 pm
Uh, where did you find your new CV's? Mine have been shot for quite some time now, and I've been having a bit of a time finding them.
Could you take a few pics while you're doing that?
PostPosted: Tue Dec 01, 2009 3:35 am
prepare yourself, its not fun.
i had to do it on a 87 isuzu pickup i had, and i had a 2 post lift at my disposal.
lots of bleeding knuckles and many 4 letter words yelled, and the dammit wrench flew more than once.
but me and another guy got it done in about 4 hrs, of course the first 3 hrs were spent trying to find out why the son of b_tch wouldnt come out, and the last hr was dropping the front end and doing it the right way!
zyanug
76 fleetside 350hp 1968 327cu
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Tue Dec 01, 2009 9:23 am
I can get axle assy's at my local NAPA store for $61 bucks with core.
PostPosted: Tue Dec 01, 2009 11:10 am
lol, sounds like this is another one that's gonna haveta wait til spring... I have access to the facilities, but dang that sounds bad. Removing the front end? If anyone wants, I'll take pics of the process.
I'll try it... hopefully it doesn't have to wait til spring.
Thanks for the information.
PostPosted: Tue Dec 01, 2009 5:30 pm
I found them at Oreilly's it's $59 with a $60 core
PostPosted: Wed Dec 02, 2009 3:29 am
Australian LUV Guru
You don't have to drop the entire front axel assy. to change out a c/v :)
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Wed Dec 02, 2009 3:53 am
Can I just take the hub/shock absorber off, or better yet, how do you do it?
PostPosted: Wed Dec 02, 2009 1:08 pm
Australian LUV Guru
I'll post up an How-To link shortly 8)
PostPosted: Fri Dec 04, 2009 4:50 am
Awesome. Thanks man!
PostPosted: Fri Dec 04, 2009 8:59 pm
Australian LUV Guru
Can't find the link so i'll do a brief how to.
1. Place truck on jack stands and remove wheel
2. Remove locking hub and take off cv shaft retaining circlip.
3. Undo two bolts holding brake caliper , remove and tie up out of way.
4. Release Top and Bottom ball joints and remove spindle/rotor.
5. Peel back boot on inner cv joint and remove wire retaining ring (see pic below
6. Cv shaft should now pull out of cup, replace with new.
No need to drop front pumpkin/axel assy unless pictured cup is badly damaged.
PostPosted: Sun Dec 06, 2009 3:55 pm
That sounds a bit easier. Much appreciated!
PostPosted: Sun Dec 06, 2009 5:53 pm
They sound like refurbish or or rebuilt CV axles. Nothing wrong with that I had my daughters done at a place that just did that. It cost less than I could buy the parts for and they guaranteed it for 1 year...
I did my 4x4 like above when I had it.. I replaced the cv joint back then.
PostPosted: Wed Dec 09, 2009 6:26 pm
Dang... lol, with 198,000 miles on the truck, it sounds to be about time for the CV's to be replaced/rebuilt. Does anyone know where I could get the bearings from? And, because the cup is a wear surface, wouldn't that present problems with the new bearings wearing incorrectly?
Thanks for the directions Oz. I'll try that first.
Oh, and how can you tell whether or not the cups are too worn?
PostPosted: Wed Dec 09, 2009 7:06 pm
I haven't had to replace the ones in my Luv but I have replaced some in other vehicles. I haven't had to replace a cup yet. I inspect mine to make sure where the berings ride inside the cup still has a definitive line and isn't rounded out. (it would have had to slip to do that or have been SEVERELY/DANGEROUSLY worn). The pic that OZ posted looks good from the pic. Look for any other damage like cracks, pits and any other thing that doesn't look normal. Make sure there isn't to much play in and out or up and down with the cup either. I'm sure my time is coming for my Luv as well.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Sat Dec 12, 2009 2:41 am
lol, sounds like I'm gonna get to drop the front end... My CV's make a nasty crunching sound when I turn very sharp. I'll take step by step photos when I get around to it. I'll still wait to see the inside of the cup before I get into that surgery though.
Thanks for the advise.
PostPosted: Sat Dec 19, 2009 1:12 am
BTW, NAPA says that new CV shafts are $300 ea.
AutoZone says $100 ea.
Checker/Schucks/Kragen says $150 ea.
Also, it says that it fits mid '80s Troopers too.
PostPosted: Sat Dec 19, 2009 5:46 am
NAPA says $300 each... 8O. That hurts since I buy everything I can from NAPA. Hopefully it will be a long time before I need to replace mine. Hell I would think we could buy a toyota front axle assembly and and do whatever fabrications necessary to install and make it work for cheaper than $600. Maybe it's time I look into that as an alternative for when my time comes.
1981 Luv 2WD
1981 Luv parts trk
PostPosted: Sat Dec 19, 2009 9:14 am
My local shop told me he can get mine rebuilt for about $55. each.
Mine seem fine, but the boots are torn and it's been through mud and dirt with the torn boots. I'm going to be redoing the whole front end here soon and was wondering if I can clean, re-grease, and install new boots on my cv's. How complex are cv joints? Can I get in there with brake cleaner or solvent well enough to get them clean?
