It is currently Tue Jun 09, 2026 1:29 pm
PostPosted: Fri Oct 24, 2008 9:01 pm
i have a very bad back and want to know if anyone has a or knows where i can find an automatic 4x4 tranny for my luv. thanks.
PostPosted: Fri Oct 24, 2008 9:13 pm
The 4X4 LUVs only came in a 4 speed manual. The transfer case and trans is all one piece.
I wonder, ( maybe someone else on here knows) if any of the Troopers came in a 4X4 auto trans. that would work.
PostPosted: Sat Oct 25, 2008 3:20 am
yes i know that a trooper will work. it is that i have not seen a auto tranny one. thats why i am asking for help.
PostPosted: Sat Oct 25, 2008 1:09 pm
In theory you might be able to find a trooper 88 to 91 with a 4 cylinder and an automatic and it would bolt up to the LUV motor. I'm not sure if you could get a flex plate that would match up to a torque converter for that trans and you might have to do some custom driveline work, but enough would bolt together that it might work.
I think I'd just go ahead and swap the motor or swap the LUV over to an Auto trans Trooper frame. With all the little iffy stuff here and there swapping just the trans, sounds like more work and less pay off than going for more of a conversion. But, that is just my opinion.
PostPosted: Tue Nov 04, 2008 4:52 pm
I have a 4X4 and is selling everything, all 4X4 stuff, engine, 4 speed tranny, transfercase, drive shaft, rearend, everything. So if you need anything let me know.
