It is currently Sun Jun 28, 2026 4:34 am
PostPosted: Mon Nov 09, 2009 9:05 pm
I just swapped in a 2.3L Trooper II motor with matching 5 speed transmission. Noticed a whine in neutral when I was driving the Trooper. When the motor was out, I checked the clutch and throwout bearing for any issues. Everything was working great and looked good when I took the transmission off. Now that I have it in the Luv, I noticed the front driveline rotating really slowly in neutral/2H. What do I need to do to fix this? I would guess it's just a problem with the transfer case not fully disengaging and some parts need replacement. Any help would be great. Thanks
PostPosted: Wed Nov 11, 2009 9:17 pm
A few questions for you. Does it make any abnormal noise when you drive it? Does it work OK in 4WD and shift like it's suppose to between 4 Hi and 4Lo? What happens if you leave it in neutral 2H and lock the front hubs...does the front drive shaft keep spinning and try to move the truck? I haven't noticed mine doing this but I have never checked.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Sat Nov 14, 2009 11:28 am
False alarm... I did not have my new rear driveline in and the oil filled in the transmission yet. So it was not coming out of gear completely after all the messing around I did with the engine/trans swap and making the shift boots work. As soon as I filled the oil up, it stopped. Luckily I only had the engine running for a couple minutes to check for leaks and stuff, so I think I didn't hurt anything. Clutch has a problem, but transfer case is fine. I guess if anybody notices their front drive shaft moving a little in neutral, the transfer case is super low on oil! Thanks for trying to help.
PostPosted: Sat Nov 14, 2009 2:48 pm
hmmmm, this may be something or nothing at all. I have seen what I guess would be called residual movements of drive shafts before like you mentioned in other vehicles but I've just never checked my Luv.
1981 Luv 2WD
1981 Luv parts trk
Users browsing this forum: Google [Bot] and 23 guests
