It is currently Sun Jun 28, 2026 4:34 am
PostPosted: Sun Jun 01, 2008 3:11 pm
ok i undid all ifs crap but steering box for high steer kit, grinded down all the pieces so it is all frame but having problems mounting it to the frame correctly with the right pinion angle and tire in the right place in the wheel well im using leaf springs so if any ideas much appreciative thank you.... HELP!!!!!!!!!!!!!!!!!!!!
PostPosted: Thu Jun 05, 2008 10:53 pm
honestly these things are alot of trial and error. Just get the axle bolted to the springs, roll it under the truck and move it around untill it looks right...
PostPosted: Thu Jul 10, 2008 10:29 am
I can write more later, but algin the axle to the rear axle, measure from corner to corner etc. There is no trial and error... Do it right, put it under, measure measure measure. Buy a degree finder (angle-o-meter as i like to call it :D ) your pinion angle on the front is not nearly as important as your caster angle(angle that the knuckles/"C's",ride at). What axle are you running? that will determine what angle you need to run, otherwise if you want to really mess with the pinion angle it requires a cut and turn of the knuckles. If you want it centered or pushed further forward in the wheel wells look into different springs with the spring pin offset further forward OR I have seen people "cheat" and drill a hole about 1" back on the spring perches to push the axle farther forward for better approach angles.
Hope that helps some. PM if you have anymore questions!
:eugeek
Aaron
I see you're in vancouver, if you ever get to the seattle area, I have to terittory up here that is begging for some wheeling (reiter trails) :twisted:
PostPosted: Sun Jul 13, 2008 8:58 pm
what part of vanouver are you i might be able to give you a hand
PostPosted: Mon Jul 14, 2008 11:32 am
I am not trying to send you somewhere else, but you may want to check out http://www.pirate4x4.com/ too. Not as much Luv Truck only, but a ton of SAS
Users browsing this forum: Google [Bot] and 25 guests
