It is currently Sun Jun 28, 2026 3:05 am
PostPosted: Wed Jul 09, 2008 11:16 am
I did a search but came up kind of empty. My second LUV I got free as a parts truck its a 4x4 Luv. I just pulled the engine on it and am building a 350 for it right now. My question is what combos do most use. I have my eye on a set of Toyota Axles but what about tranny and T case? Local shop said advance adapters makes a kit for toyota transmission from 350.
Wanted to see what had been done work or not.
PostPosted: Wed Jul 09, 2008 7:14 pm
http://forums.luvtruck.com/viewtopic.php?f=24&t=15832 this post might help and this one has some pics http://forums.luvtruck.com/viewtopic.php?f=24&t=13640 i think he is the only 350 4x4 on this site he would be the one to talk to but i dont think he has posted in a while
No luv right now =(
PostPosted: Thu Jul 10, 2008 10:19 am
Hey, I haven;t posted in a while cus I got rid of the project. :oops:
I was short on time and money and everything else in between, so i got rid of it. :roll:
But if you have any questions on setups just ask. I still lurh around on this board and in time.... There will be a bigger badder luv project in the works.... :ebiggrin
I would suggest a th350 or th400 I would lean more toward the th400, stronger, I would mate it to a np205, prolly the easiest/cheapest route, and aside from being a bit on the heavy side. it is very strong. make sure to do some research on tailshaft splines etc. you can ALMOST find a style of np203 or np205 or np208 that will bolt up to a th350, th400 or 700r4.
I personally have a 350 TBI to a 700r4, back to a np203/np205 doubler that is driver's drop to a HP Dana 44. :D I am almost ready to test this setup out...
I was running the 700r4 to a np207 then to a np231, both worked great and had low gearing.
Aaron
