It is currently Fri Jun 26, 2026 10:41 am
 Post subject: front drive shaft swap ?
PostPosted: Thu Jun 05, 2008 8:01 pm
I have a 1980 4x4 and the front drive shaft is worn out. Will one out of a 81 luv work and will one out of a trooper work, if so what year or years of troopers will work?
PostPosted: Thu Jun 05, 2008 8:55 pm
Australian LUV Guru
If you're talking bout the shaft from the transfer case to diff, the 81 luv will fit. Not sure if a Trooper shaft will fit, the Troop,s wheelbase might be longer.
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Thu Jun 05, 2008 10:47 pm
If the trooper has a 4speed it would work. The output on the 5speeds transfer case is a larger diameter than the 4 speed. So stick with 4 speed Isuzu 4x4s, wich basicly means LUVs...
