It is currently Fri Jun 26, 2026 9:34 am
 Post subject: Questions for you gurus.
PostPosted: Sun Jun 01, 2008 2:09 am
Say I was to buy parts off of this: (http://tulsa.craigslist.org/pts/702728981.html). What would I need for my SAS? I would assume both axles, both drivelines, and the transfer case... But what else would I need? And would the transfer case even hook up or could I use my stock one? Also, what would be a good price on what I need? Or is $300 for the vehicle and using it for parts and then scrapping the rest good?
Thanks all.
PostPosted: Sun Jun 01, 2008 9:07 am
I would get the whole thing, that way I would be sure to have everything available.
PostPosted: Sun Jun 01, 2008 1:58 pm
i would buy the whole vehicle. are you swaping the straight six also? if your keeping the luv engine and trans i don't know what t-cases if any you could swap into it. i would get both drive shafts, they willl both probably have to be modified any ways. you definitly need the front axle. i run the stock rear on mine but i think the jeep one would be better, plus the wheels would be the same if you did. i would talk to boonie buster he knows alot more about it than i do. for 300$ you cant go wrong
No luv right now =(
Users browsing this forum: Google [Bot] and 8 guests
