It is currently Fri Jun 26, 2026 3:31 am
 Post subject: torchin bar remove
PostPosted: Thu May 08, 2008 10:32 pm
i have been working on my 80 chevy luv i have the reforced toyota axles 35 12.5 15 wheel tire combo im puting 5.29 lockers front rear the only problem is that torchin bar will will not come out it is the only thing holding me back i tryd having lifting it out of the brace and try'd hamering it out but it will not come out not at all im not going back with the same system so what do i need to do i also try'd do ing it with a c clamp and it also no worky
 Post subject: Re: torchin bar remove
PostPosted: Fri May 09, 2008 3:17 pm
Mine also would not come out so I attached a ratcheting tie down strap to the adjustment end and around the next crossmember back. I used the strap to apply pulling pressure and with a dead blow hammer hitting on the adjuster moving it up and down, tightening the strap as the bar came out. Hope this helps. :) I also used some penatraiting lube.
