tumwatertaz wrote:
Or clean them up, use a little rust preventive on them, and just fiberglass them. I put webbing and resin (two coats) on the underside and on the inside of mine and they are strong as the dickens. Just make sure you spray a litle primer and paint on both sides when you are done. It's a lot easier than welding new sheet metal in and they'll never rust or leak again.
Taz, that sounds like a good option on rusted floors. How clean do you need to get the rusted floor? As you can see in endless expenses' pic there is a lot of loose rust as well as not so loose rust. What method did you use to clean yours, sanding, brushing or blasting? Also what type of rust preventative did you use and what is the function (to remove or to cover/bond)
endless, don't mean to highjack your post, please excuse.
