It is currently Thu Jun 25, 2026 4:59 pm
 Post subject: rims
PostPosted: Sun Feb 17, 2008 11:29 pm
i'm on the look out for new rims and thought i would look for a new set and found this...
http://www.tirerack.com/wheels/WheelClo ... sort=Price
wow that was a huge link!!! is this the bolt pattern? 6-139
 Post subject: Re: rims
PostPosted: Sun Feb 17, 2008 11:49 pm
Yes, that's the bolt pattern. They're 6x5.5", which is 6x139.7
Everyone rounds that to 6x139.
On the 4x4, the center hole needs to clear the front hub, which is 91 mm.
A slight negative offset (tire moved inward toward the center of the car) gives a little more clearance on bigger tires. I recommend 15-25 mm. I have 25 mm on mine.
You went there in that?!?!
PostPosted: Mon Feb 18, 2008 7:09 am
i'm pretty good as far as clearance goes but i really appreciate the info.!!! :D
