It is currently Wed Jun 17, 2026 3:04 am
 Post subject: What axles
PostPosted: Tue Mar 11, 2008 8:44 pm
I was wondering what axles you guys use when you go to solid axles. i just picked up a 79 4x4 luv with a 4 cylinder and a manual. I want to go to solid suspension and dont know what axles to use. thanks in advance.
 Post subject: Re: What axles
PostPosted: Tue Mar 11, 2008 11:28 pm
look at this it should help http://forums.luvtruck.com/viewtopic.php?f=24&t=16483
No luv right now =(
PostPosted: Wed Oct 08, 2008 2:48 pm
post resurrector
One tons all the way.dana 60 front, 14 bolt rear.
'80 luv 4wd 6.0 vortec hurst 4spd process of lifting
'69 f-100 4wd 14" lift and 44s
'03 f-150 4dr 4wd daily
BOOMER SOONER!!!
PostPosted: Wed Oct 08, 2008 5:52 pm
This is rather overkill, with these axles, you'd double the weight of the truck and need a whole new drivetrain. Not to mention you'd need to run a 4" taller tire with these bad boys to have the same ground clearance as a yota ( example 33;s on yota = ground clearance of 37's on one tons)
If thats what you wanting to do, then by all means, but the yota front axle is the easiest and most efficient.
My current DD is a one ton Chevy and has a 60 and 14bff, but it also weighs 4 tons and makes 400 ft lbs,
not 1 ton , making~90 ft lbs! haha
PostPosted: Thu Oct 09, 2008 8:08 am
post resurrector
Yeah it does all depend on how serious you want to get, but the way I look at it if your going to do it go big or go home.
BOOMER SOONER!!!
