It is currently Mon Jun 29, 2026 11:02 am
 Post subject: 4x4 Help Needed
PostPosted: Fri Aug 24, 2007 2:04 pm
Australian LUV Guru
Help, can someone tell me how to get the half shafts out the front diff? Im wanting to replace the oil seals. I thought they would just slide out by the looks of the picture.
Thanks.
1980 4x4 KBD40 ISUZU/Chev Luv
 Post subject: seals
PostPosted: Fri Aug 24, 2007 6:37 pm
Whe I did the CV boots on my 78 they pulled out. It did take some tugging to get them out but they came. The ends I had just had a c-clip that was holding the shaft into the diff.
Craig
 Post subject: .
PostPosted: Fri Aug 24, 2007 7:42 pm
Maybe a good rap with a rubber mallet on the outer part of the shaft.
FIAA: Color Guard
 Post subject: Re: seals
PostPosted: Sat Aug 25, 2007 6:13 am
Australian LUV Guru
Craig
Craig, if i read correctly you are saying the cv cup (see attach pic) will pull out of the diff. Other forums have told me i need to drop the whole diff housing. I cant see how that is possible without removing the shown cups first. :?
PostPosted: Sat Aug 25, 2007 2:55 pm
PITA Old Fart
Once the end that is connected to the front wheel is out and the wheel is swung out of the way, then the other end just pops out because it is just held in by a rounded c-clip that sits in a little groove. Some can be a real bitch to get out, and if you yank too hard and too much on them, you can damage the internal parts of the joint mechanism.
Try getting a huge flat screwdiver or a long narrow flat prybar in between the end of the axle and the transfer case housing and pry until it pops out. You might even have to pry from equally opposing sides to get a good straight pull on it to get it to finally give.
Keep a rag handy, because once it comes out, usually oil pours out on the floor from the opening it goes into.
And whoever told you you have to drop the whole transfer case just to change your half-shafts really needs to stop smokin' that stuff and sober up...lol
 Post subject: Cv
PostPosted: Sat Aug 25, 2007 6:21 pm
dont pull the diff! just pry and they will pull out. tumwater is right. don't waste your time pulling the diff.8O 8O 8O 8O 8O 8O 8O
thanks,
Craig
 Post subject: Re: Cv
PostPosted: Sat Aug 25, 2007 9:56 pm
Australian LUV Guru
ridgway369 wrote:
Thanks for the info guys, btw the info about dropping the diff was provided by someone more familiar with newer model Isuzu's.
 Post subject: CV's
PostPosted: Sun Aug 26, 2007 5:08 am
you wouldn't come back if you didn't get help and crap from other members. It's like one big family :P
PostPosted: Wed Sep 05, 2007 11:17 pm
Australian LUV Guru
I still haven't had any luck getting my shafts out :? I have a Haynes but it has no info about 4x4, could somebody please post pics/info about shaft removal if you have a 4x4 manual. I not 100% convinced that its only a c clip holding the shaft in the housing. Thanks
PostPosted: Thu Sep 06, 2007 9:23 pm
I'll try to scan and post some pages out of the manual I have for all years tomorrow. I'm on the wrong computer tonight.
PostPosted: Thu Sep 06, 2007 9:35 pm
I prefer a good size deadblow or a big rubber hammer.... some are more stubbern than others
Cant speak for the LUV tho... no experience with it
PostPosted: Sat Sep 08, 2007 4:21 am
Australian LUV Guru
I finally got the cv cups out, the only way to remove them is to drop the whole diff housing out off the Luv.
Image Image
PostPosted: Sat Sep 08, 2007 9:23 am
I guess I'm too late. Sorry. But here is what I have anyway.
