It is currently Tue Jun 30, 2026 5:45 pm
PostPosted: Tue May 15, 2007 4:22 am
Australian LUV Guru
If you have a body lift kit installed to your Luv could you please answer me this simple question? Are the two lift spacers below the radiator support panel the SAME thickness as the four spacers under the cab? Thankyou for any input 8)
PostPosted: Tue May 15, 2007 12:35 pm
Banishment Pending
yes..they are the same size/thickness :D
PostPosted: Tue May 15, 2007 7:30 pm
The kits should come with 6 slightly taller spacers and a number of ones that are slightly shorter. The 6 are for the cab mounts and the shorter ones are for the bed. If you build your own kit (washers, hockey pucks, water pipe) you could make them all the same size if you put the rubber cab mounts back on with the ones under the cab.
