It is currently Thu Jul 02, 2026 3:31 pm
PostPosted: Sat Jan 13, 2007 3:27 pm
What years swap in my 80 from a trooper, etc.
PostPosted: Sat Jan 13, 2007 3:47 pm
If its a 4speed its the same. If its a 5speed then you could do it but it will take some fab worb. A member not long ago did this (swapping in a 5speed) so just do search...
PostPosted: Sat Jan 13, 2007 4:00 pm
it's the 4spd, what transfer case did the 1980 have in it.
PostPosted: Sun Jan 14, 2007 11:51 am
If your asking about the LUV, the transfer case and 4 speed trans. is all one piece.
PostPosted: Sun Jan 14, 2007 12:31 pm
:oops: I did not know that!!!
PostPosted: Sun Jan 14, 2007 10:53 pm
Banishment Pending
:smt075
And your a Mod????!!!! :twisted:
The Luv t-case and tranny are all one unit as said above. as far as Trooper stuff fitting, the 4 speed Trooper tranny (84-85) is a direct swap in, the later 5-speeds will require a bit of fab work to get them to work and the years that you would be looking for would be 86-87.5.
